How To Install A TC Drop *Write Up* - Page 3 - JeepForum.com
post #31 of 41 Old 08-10-2007, 09:22 AM Thread Starter
XJK
The Guru of Nothing
XJK's Avatar
well you have the stud, which just sits there and is being held in from inside the frame.
at this point the crossmember is out of the way.
put the nut that you took off of the stud back on the stud.
then put another nut below the nut that you just put on that stud and make sure its very tight
slip your wrench over the bottom nut on to the top one.
start loosening the stud, the top nut wont move because the bottom nut is in the way therefore the stud will be able to come out.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #32 of 41 Old 11-13-2007, 07:13 AM
Kieffer87
Not to bring back an old thread but everyone is talking about stripping the threads on the stud. Don't you use a new bolt anyways?
Kieffer87 is offline
post #33 of 41 Old 09-22-2008, 09:42 PM
suzukisailor315
1989 XJ Cherokee
[QUOTE=XJ99;3636327]Cut a small hole in the frame and weld another nut in place, or a stud..
why do you have to do this?
im a tad confused.
suzukisailor315 is offline
post #34 of 41 Old 11-12-2008, 10:05 PM
ClassicVA
would there be any adverse affect if you installed a TC drop on a stock cherokee if you're planning on lifting it in the future? aka: make something bind up or anything of the nature?
~1998 Cherokee Classic - 3.5" RE Superflex, 32's
~XJ Owners Club Member #134
ClassicVA is offline
post #35 of 41 Old 11-12-2008, 10:58 PM
srmitchell
Nope. Some people had some vibes stock, and the stealership did something like a tcase drop to fix it.
I'd wait till you lift it though.
Stuff hangs up otherwise.
I work on Mopars
srmitchell is offline
post #36 of 41 Old 11-13-2008, 12:01 AM
ClassicVA
10-4
i'll keep that in mind
post #37 of 41 Old 11-15-2009, 03:14 PM
E-Dubs88XJ
Originally Posted by WMW0505 View Post
and if the double nut doesn't work use a pipe wrench and a hammer...thats what we did on my bros 97...the double nuts stripped the threads so we just took a pipe wrench and hammered it on and it turned right out.
Oh and if you dont wanna buy one you can make one for a few bucks at ACE...just get some 1" square tubing and longer bolts and you are ready to go.
This really helped me out. I just did this on my 98XJ and I tried the 2 nuts, it stripped the threads. Then i used a pipe wrench and they both came out not to bad at all. The 1" square metal tubing I bought from ace seems a little this but hopefully it holds up good. I just used a come-along to line up the holes again. I strapped it to the leaf spring and the cross member and slowly cranked down on the come-along to get them to line up. My vibes are gone, very very slight vibes, but someone in the car with me would not even notice.
Thanks much guys
Currently a 1998 XJ With a RE 3.5" SR kit, OME long travel shocks, RE track bar, Gas tank skid plate, Chrysler 8.25 rear, 31"x10.5" Grabber AT2 tires on 15.5" rims with a 3.75 BS.
E-Dubs88XJ is offline
post #38 of 41 Old 01-10-2010, 04:16 PM
98GooseXJ14
1997 XJ Cherokee
This may be what I will try and do until spring and warmer weather comes along. I'll try the 1" square tube with a lot of pb blaster.
2000 Jeep Cherokee XJ 95k miles - Sold
1998 Jeep Cherokee XJ 160k miles - Killed/Sold
1997 Cherokee XJ 173k miles 5spd Killed/Sold
98GooseXJ14 is offline
post #39 of 41 Old 02-26-2010, 04:11 PM
98_XJ
Anyone know the nut size we need to do this?
1998 Jeep XJ Limited 4x4
- Rough Country Series II 3" Lift
- 31-10.50-15 Duratracs on Black Rocks
- JCR Offroad Stage 3 Front Bumper
2010 Chevy Equinox
98_XJ is offline
post #40 of 41 Old 12-29-2011, 11:01 PM
RedRider1
On my 01 Cherokee it has a stud on each side that sticks out from inside the frame, are these double ended studs on all Jeeps that will come out with the 2 nut trick? i want to do a tc drop but dont want the stud to break off and be s.o.l.
RedRider1 is offline
post #41 of 41 Old 01-09-2012, 11:20 AM
JCJeep97
Man, what a help. . . . even though I'm taking mine off
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
RC LA install write-up Muddeprived XJ Cherokee Technical Forum 35 10-29-2012 12:09 AM
8.8 install write up? BIGNUTT XJ Cherokee Technical Forum 4 02-10-2010 08:46 AM
gear install write-up?? C-Mil XJ Cherokee Technical Forum 1 11-27-2009 03:21 PM
RE 5.5" LA install write up? NIN20 XJ Cherokee Technical Forum 1 07-19-2009 05:34 PM
Aussie Install Write for C8.25??? rc76 XJ Cherokee Technical Forum 4 05-28-2009 04:23 AM
