How-To: I just put new floorpans and patched holes in the XJ (Lots of Pics)
| RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road |
#1 | |
Well, I finished putting in the new floorpans and patching the holes in the XJ the other day, so here are the pics of the process in a How-To form. This is going to be LONG so hang on.
What you need: New floorpans (I used Sherman Parts floorpans, cost $238 with tax) An angle grinder with cutoff wheel, and grinding wheel Chissel Rubber Mallet Balpine Hammer Not sure of the name, but I call it a Spike hammer. It has a spike on one side, and a big flat round end on the other end. I think it is for body work. Center Punch Welder Welding Blanket Shop Vac for all the little bits Screw driver Box knife to cut up the old carpet A drill with abbrasive wheel Spot weld cutter (I used a big drill bit, but you have to be careful with a drill bit) Drill bits for drilling holes for spotwelds, and seat bolts Various sizes of hole saws for drain plugs Safty glasses Ear plugs Dust mask, unless you want to breath in all the rust dust Seam Sealer Ratchet set T47 Torx bit for the seat belts T40 Torx bit for the rear hatch latch Sharpie UNPLUG your battery, I have heard that welding with the battery in could possibly ruin the computer, also it keeps the dome light from running the battery down, because this project will take awhile. Now for the fun part. First you need to take out your seats, spare tire, interior pannels and console (I left the Shifter console in, but it would be best to take it out). I didn't take out my seat belts until the end, because I am about to Herculiner the inside. I would recomend taking them out in the beginning, because they can get in the way. Now that all of that is out of the way, it is time to take the carpet out. I actually found the horn button under the carpet. I saw it, and thought "what is this" then I realized what it was, now my steering wheel doesn't look empty. This is one of the times you need that dust mask, It probably isn't good to breath the all of the dust that comes up. My carpet was soaked, so I cut it into sections to make it easier, and so I didn't get as wet. There is some padding that is under the dash that is not part of the carpet, I took it out too. I also found some insulation stuff that was around the fuse box and in the same spot on the passenger side. I took it out so it wouldn't catch on fire. Next I went through with the drill and abrasive wheel, to get all of the loose stuff up. You will probably want a dust mask for this part too. I also used a Ruber Mallet and Chissel to cut away the stock Seam Sealer (It is a little quicker if you heat up the sealer with a heat gun). Now you need to Vacuum up all the little bits. There was alot of stuff in mine, I think the previous owner hauld a dog in mine, there was ALOT of dog hair. I had to empty my Shop Vac a few times, but I was using a small one. Here are the Brand New, Shiny Floor pans. I think this is the best way to go. the pans fit PERFECTLY. Only some minor modification was made to get the pans to form to the dimples on the back of the transmission tunnel (hince the two hammers you will need). ![]() Here are some test fit pics before I got to cutting. To make the holes for the holes for the seat studs, so I could get the pans to slide in. I put a dab of Flourescent Orange paint on the tips and set the pans down on top, then drilled out where the paint transfered. Once I got them in, I traced the edges with a Sharpie so I would know my limit of cutting. ![]() ![]()
'87 XJ: Front 3-link with coilovers, sits at 4.5" of lift | Custom front bumper | Custom rear bumper | Custom Rock Rails | Tow hooks and Rear hitch | Warn M8000 | Racing seats | Factory D44 in the rear | 33x12.50 Interco TrXus MT's on Mickey Thompson 15x8 Classic Lock's | 4.56 gears | ECTED's front and rear | RCV front axle shafts Blue Jeep Club #244 Last edited by TMXONR; 02-09-2007 at 08:19 AM.. |
#2 |
Time to start cutting. WATCH OUT FOR FUEL LINES AND OTHER THINGS UNDER THE FLOOR. I used an Angle Grider with a cut-off wheel. When I got to the non rusted metal, I used a drill bit to cut the spot welds, and a rubber mallet and chissel to break them the rest of the way. You will want to vacuum out your Uniframe rail after this.
The first casualties, the shiny, new looking metal was my first attempt at making my own floorpans. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'87 XJ: Front 3-link with coilovers, sits at 4.5" of lift | Custom front bumper | Custom rear bumper | Custom Rock Rails | Tow hooks and Rear hitch | Warn M8000 | Racing seats | Factory D44 in the rear | 33x12.50 Interco TrXus MT's on Mickey Thompson 15x8 Classic Lock's | 4.56 gears | ECTED's front and rear | RCV front axle shafts Blue Jeep Club #244 |
#3 |
Next I drilled all the spotweld holes, and the holes above the T-Case Skid studs. I traced the Uniframe rail from under the Jeep with a Sharpie, so I would know where to drill the holes (This took a while, I would recomend marking and center punching the holes before you start to drill. I drilled a few to hold down the side of the transmission tunnel, but I still welded up the entire seam. It makes it alot easier when you are not chasing the drill bit.
![]() ![]() ![]() Now It is time to weld. You dont want to weld all in one spot, or the metal will warp. I started in the middle and worked my way to the front and back. When doing the transmission side I did alot of spotwelds in about one half to one inch lengths, and spaced the sections out so not to warp the metal. Use your welding blanket to cover anything up that you don't want bits of hot metal to land on. ![]() ![]() Now before you start on the Passenger side, you need to put the grinding wheel on the angle grinder and clean up any big welds (I had a couple, they weren't real bad, but they weren't as flush with the floor as the othe spot welds. Now its time to start on the passenger side. Heres is what I started out with. This is about what the drivers side looked like. Same cautions apply to this side as did apply to the drivers side. If you use something like a Sawzall to cut the floor instead of a cut-off whee, watch out for the exhaust. ![]() ![]() Here are some test fit pics. ![]() ![]() ![]()
'87 XJ: Front 3-link with coilovers, sits at 4.5" of lift | Custom front bumper | Custom rear bumper | Custom Rock Rails | Tow hooks and Rear hitch | Warn M8000 | Racing seats | Factory D44 in the rear | 33x12.50 Interco TrXus MT's on Mickey Thompson 15x8 Classic Lock's | 4.56 gears | ECTED's front and rear | RCV front axle shafts Blue Jeep Club #244 Last edited by TMXONR; 02-09-2007 at 08:21 AM.. |
#4 |
Now It's cutting time. As you can see in the pics you will need to Vacuum out the Uniframe rail
![]() ![]() ![]() ![]() ![]() ![]() Now Its time again to trace the Uniframe rail for your spotwelds. Again, mark the holes with a Sharpie, centerpunch them, and drill all of your holes. ![]() ![]() Now weld it up, I didn't get any pics of the Passenger side right after welding, but it looks like the Drives side. Now that the welding is done I went through the entire floor, Front and back and painted down some Rust Mort (I got it at Orielly Auto Parts). This stuff STINKS. I painted it over all of the parts that still had some rust on them. This stuff really works too. It converts the rust in to a dark brown to black substance, and is hard like metal again. After you do this and it has dried the directions say to take a wet rag and wipe the floor down. This stuff only sticks to rust, and if you paint over it with out cleaning it off of the non rusted surface, your paint will peal in that area. Now It is time to Seal all of the seams. Take your seam sealer and brush it around the edges of the floorpans where you welded. Clean the Seams first. ![]() ![]()
#5 |
This area is fully patched and sealed now, eventhough it isn't in the pic. I just took a strip of clean metal from what I cut out and made the patch
![]() ![]() ![]() ![]() Now it is time to patch any small rust holes that weren't fixed by the floorpans. I had a couple in the back to fix. Here is what they looked like. ![]() ![]() Now you want to cut out all of the rusted metal. Even though I put the Rust Mort down, These parts still needed to be fixed. ![]() ![]() Then I made the patches and test fit them. ![]() ![]()
#6 |
Now its weld time. Clean up the welds with the angle grinder when done.
![]() ![]() Hey, guess what!! Its done. Now its time to clean up the mess, and I had a big one. ![]() ![]() ![]() ![]() I backed out the Jeep and saw exactly how big the mess was. Well this was my floor ![]() Here is all of the little metal, rust bits, and dirt that fell through the floor while working. ![]() All swept up and ready to be thrown away ![]() Now It is time to do what ever you are going to do to put back in the Jeep and spray the under side where the new metal is with some under coating, I am going to use the Duplicolor Spray on beadliner. I am going to Herculiner the inside, and repaint the interior panels, because they are faded from 20 years of sunlight. I haven't done the Herculiner yet, but I will when I get a couple of good weather days when isn't cold and windy. Hope this helps anyone looking to do this. Comments welcome.
#7 |
Resident Audio Guru
Want to do my floorpans next?
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#8 |
nice job man!
#9 |
wow, excellent write up - how long did it take you? i did something similar to my trunk and it took me almost two solid days! have the herculiner interior too and i love it
[SIZE="3"]live free or die[/SIZE] [SIZE="1"]98xxx, 33's, 4.10's, and plenty of flaky red stuff[/SIZE] |
#10 | |
Time frame was Thursday, December 21, 2006, 4:13:16 PM - Tuesday, February 8, 2007. Dang, 47 days. Good thing this isn't my DD. Thanks guys
#11 |
I just did mine the same way. That was a nice write up. Mine took a month, but i only work on it 1 day a week and a hour here or there.
1996 Cherokee Sport 7.5' Meyers plow 1993 Grand Cherokee |
#12 |
Great write-up. I have to help my brother patch his floors....definitely not looking forward to it...but it has to be done.
02' Sahara Owner |
#13 |
Drivin' me nuts...
Wow. That was awesome.
It really beats riveting a coffee can onto the hole and spraying it with undercoating like I did in my old '84 Pioneer.
'99 Classic: "Emma" 8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents Jeeps with Teeth #1 MN Jeeper #14 _____________________________________________ "When is the best time to do things? Who is the most important one? What is the right thing to do?" "BORN TO WHEEL" PRODUCTS FOR SALE **********More designs here********** |
#14 |
dakuda is a god
looks good, i know how fun that job is
and i had alot less work than you |
#15 |
Great work, I feel your pain as I'm replacing the whole floor pan on my 70 Mustang under restoration. One little thing tho, I would suggest to cover the inside of the glass (windshield, doors, hatch and so on) on the car when cutting or grinding with a wheel, the red-hot spark will put a nick on the glass and it won't come off (don't ask me how I know...).
Rafa |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
