How hard to replace starter - JeepForum.com
post #1 of 14 Old 02-11-2006, 07:19 PM Thread Starter
lrsmithwhaley
1991 XJ Cherokee
I am almost positive that my problem lies with my starter. How hard is it to replace one, with very limited tools, and no experience? My Jeep is currently sitting in one of the parking lots for the dorms where I go to college, and I am almost positive I need to replace the starter, and if possible I need to do it this weekend. What all tools do I need and are there any secrets or tricks I should be aware of? Thanks!
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is offline
post #2 of 14 Old 02-11-2006, 09:04 PM
scotty'98
scotty'98's Avatar
Well i tried to take mine off too, i ran into a problem of not having a small enough/skinny enough wrench to get to the upper nut. If you think you got the tool, its not hard at all. Just my .02 and the problem that i ran into
98 XJ DOORLESS / Half doors
4.5" RC 33x12.5x15 dunlop mudrover's on SOFT 8's
K&N cold air intake
The calling does not leave you when you fail...it leaves you when you stop fighting
scotty'98 is offline
post #3 of 14 Old 02-11-2006, 09:20 PM
XJ4oh
1997 XJ Cherokee
No personal experience, but going by what people on here have said.. Just simple handtools, and about 30 minuts.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #4 of 14 Old 02-11-2006, 09:26 PM
ktmracer419
ktmracer419's Avatar
1997 XJ Cherokee
30 minutes tops.
basic handtools are needed.
1-disco battery
2-disco terminals on solenoid
3-remove 2 bolts
4-pull starter
5-insert new starter
6-insert 2 bolts
7-connect terminals on solenoid
8-re-connect battery
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline
post #5 of 14 Old 02-12-2006, 01:16 AM
EJames1226
EJames1226's Avatar
But with jeeps, you take the time you think its gonna take (30 minutes) multiply it by 2 (1 hour) then add 2 (so i think that would mean 3 hours? i suck at math) But you get the general idea.
Taking it to the dealership, or a shop is your absoloute last resort. They charged me 300 bucks to do it.
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #6 of 14 Old 02-12-2006, 01:21 AM
Blake
Redefining body roll
Blake's Avatar
It took me ~20 minutes. Also, I had to use a flex joint or two and an extension to get the top bolt out.
Don't forget to hold the starter when your taking the last bolt out. Mine landed an inch away from my head, luckily, I have fast reflexes. That could have hurt. Bad.
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
post #7 of 14 Old 02-12-2006, 02:16 AM
syzygy
If it's your first starter that you've ever done, you'll probably fight with it a little to figure out how the whole thing goes together but it is really pretty easy... if you're small enough or lifted enough you shouldn't have any problem doing it on the ground... and as said earlier, a basic set of hand tools-- just a couple bolts and a few small nuts holding on power wires and you're all set.
just make sure you disconnect the battery or you might be in for a shocking experience-- the positive battery cable goes straight to the starter... and sticking hand tools in the area can lead to some nice grounding out... sparking, etc.
Good luck!
My 3rd XJ: 1997, aka "BlackEye", 4.0/5-speed, Black. 85K mi. BDS 3" 99% INSTALLED. Goal=
syzygy is offline
post #8 of 14 Old 02-12-2006, 02:18 AM
syzygy
I suppose I should ask-- how do you know you need to replace the starter? What have you done so far? And, if you do end up replacing it, do you know where it's located on the engine? And what it looks like, and all that? I don't know how new you are to all this, so let us know so we can help...
syzygy is offline
post #9 of 14 Old 02-12-2006, 09:22 AM Thread Starter
lrsmithwhaley
1991 XJ Cherokee
I have posted a few times looking for help. I've checked all but the connections on the starter and they are good. I even replaced the battery cable terminals because one was junk. I was gonna remove the starter, clean the connections and it really good and tap it a few times, then reconnect it. If it turned on then I was gonna go get one that someone is gonna sell for $15 just so I have an extra one. I know where the starter is. I started having problems after playing in the mud so I am unsure if it is a relay or bad connection or I killed the starter. I am dead in the parking lot where I go to college and have no way to tow it to a garage and all the people that can help me are gone for the weekend and I need my Jeep tomorrow night and first thing monday morning.
post #10 of 14 Old 02-12-2006, 11:35 AM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
As stated above, easy replacement. Two bolts and three nuts to deal with. I don't remember what sizes they are but I do remember that no two are the same size ( good job DC). Safety issues are battery disconnect and eye protection, remember that mud. Good luck
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #11 of 14 Old 02-12-2006, 01:31 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
It took me about 15 or 20 minutes. You have to pull the ground from the battery, pull off 2 nuts, pull 2 bolts, wiggle the strater until it comes loose. Wiggle the new one in there and put everything back together.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #12 of 14 Old 02-12-2006, 05:45 PM
Sairys
Location: Troy Michigan, attend college at Mich Tech Univ.
I'm currently replacing mine, and managed to take the old one off, put the new one on and take it off again in about an hour with of time. With breaks for hot drinks to warm up. It's really just a matter of some nuts and bolts.
If you're stuck in a parkin' lot, try takin' a wrench and whackin' your starter a few times. That's what got mine rollin' enough to get it home today.
Sairys is offline
post #13 of 14 Old 02-12-2006, 06:22 PM Thread Starter
lrsmithwhaley
1991 XJ Cherokee
I used my tow hooks since they aren't installed yet and it started right up. I replaced the starter relay so it wasn't that. This week I am gonna get a new starter and replace it. Thanks for all the advice, now I know what to do and how to do it, so it shouldn't be bad at all.
post #14 of 14 Old 02-12-2006, 06:22 PM
sqeekers
sqeekers's Avatar
If you have a flex joint and a short and long extention to go with your general metric socket set your set at tops 30 min. I just got done putting mine back in after a new engine install
sqeekers is offline
How do i replace my starter? fourlow XJ Cherokee Technical Forum 14 07-11-2009 12:27 PM
starter & wiring harness. how hard? TwistedcaB- XJ Cherokee Technical Forum 0 07-08-2008 03:14 AM
can I replace the starter gear? Goku XJ Cherokee Technical Forum 12 11-17-2006 05:32 PM
1989 and i need to replace the starter...do it yourself job? or no? colgate41 XJ Cherokee Technical Forum 13 07-12-2006 02:45 PM
88 Comanche Hard Starter eastslip MJ Comanche Technical Forum 2 11-01-2005 07:09 PM
