How hard can it be? - JeepForum.com
post #1 of 13 Old 09-12-2012, 07:42 PM Thread Starter
JerpXJ
How hard can it be?
Ok guys, more than likely I am going to be getting an entire parts jeep for some miscellaneous big parts and spares of others, it's a '99 and I already have my project which is a 2000, unfortunately body wise my 2000 is in better shape or I would be building up the 99. However, I want to swap out the bad of the 2000, with the good from the '99 (LPD30, 0331 head, etc.) My main question is how hard is it going to be to swap out the head and other major engine components from the '99 to my 2000? I will have the whole XJ, so I should have all the necessary parts, correct? So, in order to get rid of the lpd30 thats easy, take it out and throw in the hpd30, simple, but as for engine components, in order to get rid of the infamous 0331 (which hasnt given me any guff, this is just preventative) I would have to swap out the head (obviously) any sensors on it that differ from the other, along with the coil rail for the distributor system from the '99, and more than likely the computer, which means I can probably get rid of the 1 billion sensor exhaust thats on it now. Is this making any sense? Any input would be helpful.
JerpXJ is offline
post #2 of 13 Old 09-13-2012, 04:56 PM Thread Starter
JerpXJ
Maybe its too much text, I'll try something else.
JerpXJ is offline
post #3 of 13 Old 09-13-2012, 05:47 PM
donthelegend
What does your state have in the way of emissions/inspections (assuming this is going to be licensed/driven on the road)? What you are proposing is very doable, and while you would be able to swap the emission systems from the '99 which would at least be an attempt to stay legal, it probably wouldn't actually be legal to the letter of the law. So that part would depend on state and local laws. But mechanically and electrically, there's no reason I know of that you can't just swap all the emissions related components on the '99 to the '00 (this would include the ECU). Just a matter of legality and whether or not that matters to you.
donthelegend is offline
post #4 of 13 Old 09-13-2012, 06:14 PM Thread Starter
JerpXJ
Thanks for the input, as for the legality of it, I am unsure. But I am honestly not too worried, if the 1999's are cruising around with that emissions system and be legal why cant my 2000? Right? And if it comes down to inspection I am really not worried, the guy that does our vehicle is a family friend and he overlooks minor things if he has to. But back to the point, so it should be a relatively easy swap if I have an entire 99' to take parts from? It seems like it should be straight forward enough.
JerpXJ is offline
post #5 of 13 Old 09-13-2012, 06:37 PM
donthelegend
Back to legality, emissions laws don't particularly make sense, and just because you have emissions equipment from one year doesn't mean putting it on another year will be legal (while that seems like it should be fine, especially given how similar those two years of the XJ are so close, in most cases it is not, especially when you are putting older equipment on a newer vehicle). I would strongly suggest making sure your friend can/will pass it before spending the time converting things and then being unable to get it licensed.
But yes, having a complete donor vehicle should reduce headaches and make sure you have everything you need (FWIW, you should be able to swap the entire '99 onto/into the '00, so mixing and matching with complete vehicles should be fine for you once you figure out which pieces you need). I'd make sure you make notes anyplace you start changing wiring though, since colors are usually different between years, and if you ever have to go back and troubleshoot anything, knowing which year wiring diagram to look at is going to come in handy.
post #6 of 13 Old 09-13-2012, 06:43 PM Thread Starter
JerpXJ
Alright, thanks for the insight. I mean I'm just getting the parts jeep for the axles and other miscellaneous stuff, but I figured if I could get rid of the 0331 head before it had a chance to fail, I would be doing myself a favor.
JerpXJ is offline
post #7 of 13 Old 09-14-2012, 12:53 PM
cj847
It seems quite doable, but I personally wouldn't mess with it. Remember that bad new travels fast. OK, so jeep sold 300,000 (I made that number up) heads with casting #331. How many have failed....a few hundred or even a few thousand? I'd take my chances and drive what I had. Put the spare head in your garage for that 1 in 300 chance of a rainy day, but don't throw money at it because someone else had a problem.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #8 of 13 Old 09-16-2012, 03:56 PM Thread Starter
JerpXJ
Like I said, the head has given me no trouble thus far, my XJ has around 130,000 on it, so it probably would be dead by now if it was going to fail, especially after how the P.O. treated it.
JerpXJ is offline
post #9 of 13 Old 09-16-2012, 04:04 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the 0331 head really concerns you, part out the 99 and buy a good used 2002+ TUPY 0331 head from a Wrangler or Grand Cherokee. The TUPY 0331 head is updated to prevent cracking.
Attempting to swap emissions systems or computers from 99 to 2000-01 is more trouble than it is worth.
CJ7-Tim is offline
post #10 of 13 Old 09-16-2012, 08:09 PM Thread Starter
JerpXJ
So an 02+ 0331 head is just a direct swap? I will probably go that route if I ever feel the need to get rid of the original, the 99 wasnt really all I expected so its probably not happening.
JerpXJ is offline
post #11 of 13 Old 09-16-2012, 08:13 PM
CJ7-Tim
CJ7-Tim's Avatar
Yes.
CJ7-Tim is offline
post #12 of 13 Old 09-17-2012, 01:37 AM
oakmckinley
OMG, I love that. I am a sucker for spongebob.
FWIW my 2000 "0331" head has given me no problems. So I agree with above that not all mean eminent failure.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #13 of 13 Old 09-17-2012, 06:48 AM Thread Starter
JerpXJ
I figured as much since it hasnt given me any trouble so far, plus with the vehicles I grew up driving I have formed a habit of watching my gauges quite often.
JerpXJ is offline
4.0 swap , xj
XJ jerks hard when i accelerate hard CJYJTJ XJ Cherokee Technical Forum 2 06-13-2010 08:18 PM
How hard to get the CPS out from up top? 95cherokee33s XJ Cherokee Technical Forum 11 12-15-2006 06:34 PM
hard to start after ran hard. The Golden One XJ Cherokee Technical Forum 2 10-21-2004 11:24 PM
How hard is it! muddy bike XJ Cherokee Technical Forum 1 06-26-2004 04:15 AM
How hard is a SYE?? bassicrob XJ Cherokee Technical Forum 7 05-31-2004 11:48 PM
