How to get rear view mirror to stay on? - JeepForum.com
post #1 of 14 Old 07-25-2011, 01:10 PM Thread Starter
samger2
I can't get my rear view mirror to stay on. I'm on my second adhesive kit in the last 2 months and the mirror won't stay on. I follow the instructions, I clean the area, I apply the base and let it set over night before attaching the mirror...what gives?
I've tried two different brands.
How can I make my rear view mirror stay put?
samger2 is offline
post #2 of 14 Old 07-25-2011, 01:30 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Use a razor blade to scrape the are clean of debris, clean it well with alchohol, apply adheisive and base, push firmly, let sit overnight, attach mirror. Mine has been on for several years and still strong. Be sure to scrape the back of the base well with the razor blade and clean it very good also.
xjfever is offline
post #3 of 14 Old 07-25-2011, 01:34 PM
Andywear
$5 from auto store. Came with sandpaper and a 2-part cement mix to glue the mirror on.
Razor blade then sand down the metal peice to get the old glue off.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #4 of 14 Old 07-25-2011, 01:54 PM
VegasJeep
VegasJeep's Avatar
A glass shop. I have paid 5 bucks once or twice and a free install a couple times. Nothing works better then what they are using..... period!
2001 XJ... 3.5" RE Lift, 31" BFGs, Bilsteins, Defender roof rack, Dana 30 HP front True Trac and 4.10s, Dana 44 Rear True Trac 4.10s, SYE, tom woods D/S, SUPER CLEAN LOW MILES
VegasJeep is offline
post #5 of 14 Old 07-25-2011, 02:00 PM Thread Starter
samger2
I think I may try a glass shop, because I've done the $5 auto store fixes. Didn't end up with a glue/cement mixture...but I wiped down the area with alcohol, used a razor blade on the glass and on the base, applied cement, let it sit with pressure, then let it sit for an entire day, then applied the mirror. Twice...
Fell off both times
samger2 is offline
post #6 of 14 Old 07-25-2011, 02:03 PM
Andywear
Well if the Jeep is setting in the +100degree sunny weather we are all having it might be worth the shop fix.
Andywear is offline
post #7 of 14 Old 07-25-2011, 02:05 PM
Andywear
Hey it says TJ why are we in the Cherokee forum?
Wrangler FTW!
Andywear is offline
post #8 of 14 Old 07-25-2011, 02:08 PM Thread Starter
samger2
Yeah, I'd say the hot weather has alot to do with it.
And I know it says Wrangler...but I drive an XJ too!!
samger2 is offline
post #9 of 14 Old 07-25-2011, 03:09 PM
ThadLS
Sand the glass where you're gonna re stick it. Glue the metal piece back on and leave it over night. Then put it back on
ThadLS is offline
post #10 of 14 Old 07-28-2011, 02:00 PM
andywitzz
5min epoxy does the job. Play with the mix long enough until it's quite sticky otherwise you'll be there for a while holding it up
andywitzz is offline
post #11 of 14 Old 07-28-2011, 02:08 PM Thread Starter
samger2
Got it put back on today. I work for a dealership and our windshield guys hooked me up and put it on for me for free.
Like a few have said here, they told me that one of the keys is to sand the base before applying any of the adhesive.
samger2 is offline
post #12 of 14 Old 07-28-2011, 08:33 PM
carenza
I just use super glue hasnt failed me yet. I have an auto dimming gentex mirror from a durango works great and looks great in an XJ
carenza is offline
post #13 of 14 Old 07-28-2011, 10:12 PM
Veeb0rg
1995 XJ Cherokee
I had this done for free at the local glass shop. The idiot glued the whole mirror on, I couldn't get it off the tab/windshield, then a few months later it fell off again. Best part was yet to come, all the extra glue he used caused the windsheild to crack when we got snow this past winter. You can see the crack starts at the excess glue and runs straight down the middle of the windshield.
Veeb0rg is offline
post #14 of 14 Old 07-28-2011, 10:22 PM
JeepZJlover
You shouldn't try and glue a mirror tabe on more then 2 times if that doesn't hold it's best to get a new windshield
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
Rear View Mirror Upside Down? XscottJ XJ Cherokee Technical Forum 2 11-16-2008 09:34 PM
Autodimming rear view mirror for 94 XJ? JWFokker XJ Cherokee Technical Forum 3 05-02-2008 08:54 PM
Removed the Rear View Mirror 4Bngr5Spd XJ Cherokee Technical Forum 11 02-27-2006 12:20 PM
Rear view mirror fell off. Help! w^rl0rd XJ Cherokee Technical Forum 14 07-16-2005 12:12 PM
little blax box above rear view mirror?? what is it beavis417 XJ Cherokee Technical Forum 7 04-22-2005 04:19 PM
