how to fix a sticking valve??? - JeepForum.com
post #1 of 7 Old 11-11-2007, 06:15 PM Thread Starter
kfeddy
ive got a 93 jeep cherokee country and i believe it has a sticking valve. what can i do to take care of it? Thanks
kfeddy is offline
post #2 of 7 Old 11-11-2007, 06:17 PM
xjpilot
xjpilot's Avatar
try some sea foam. worked for me
my jeep has the confused prerunner syndrome....4.5" in the rear and 2" in the front.
Purple Jeep Club Member # 1
xjpilot is offline
post #3 of 7 Old 11-11-2007, 07:06 PM Thread Starter
kfeddy
how much is it and were do u pour it into? thanks for the advise
kfeddy is offline
post #4 of 7 Old 11-11-2007, 07:20 PM
89warwagon
1989 XJ Cherokee
what symptoms are you experiencing?
89 xj 5.5 rubicon express,34" swamper ltb's
89warwagon is offline
post #5 of 7 Old 11-11-2007, 07:47 PM
JoeJeepWMU
1997 XJ Cherokee
Seafoam is around 7.00 dollars at NAPA and you pour it down the throttle body or use a vacuum line to suck it up into the engine. Thats about as far as my knowledge goes with seafoam.
1997 Jeep Cherokee Country 4.0 4X4 8.25 rear
2006 Jeep TJ Sport Auto White Jeep Club #90
Originally Posted by TheMightyGoat View Post
I'll do you one better. Friday afternoon.
Though to be fair I have washed my balls off in the sink once or twice.
JoeJeepWMU is offline
post #6 of 7 Old 11-11-2007, 08:06 PM
xjpilot
xjpilot's Avatar
joejeep is right, except you can get it at just about any parts store. You put it in either your throttle body, brake booster vacume line, oil, gas, or whatever you want to clean. if its going in your motor, let it set for bout an hour, and start it up. Depending on how dirty your engine is, give it 2 or 3 doses.
xjpilot is offline
post #7 of 7 Old 11-15-2013, 02:08 PM
SHOCKY
cluck sound
hi
when I turn to the right there is a cluck sound.
it sound like it is coming out from right under the right floor board.
I have a jeep Cherokee country 2001 2.5td
SHOCKY is offline
Valve stem seals? or valve lash? Godchsr XJ Cherokee Technical Forum 9 11-29-2007 02:28 PM
EGR Valve sticking or Intake/Exhaust Manifold Leak? se7vn XJ Cherokee Technical Forum 6 10-08-2007 03:56 PM
EGR Valve Sticking.....? se7vn XJ Cherokee Technical Forum 3 02-16-2007 07:59 AM
4wd sticking smokinup XJ Cherokee Technical Forum 6 12-02-2005 12:09 PM
Coolant Mixing Valve / Heater Valve Leaking - Tips needed JWeb_93YJ XJ Cherokee Technical Forum 5 03-13-2005 08:34 AM
