Quantcast How to fit 33's with 3" lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How to fit 33's with 3" lift
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 04-03-2008, 03:56 PM   #1
cardana24
I tried searching but I could not get the search function to work like I wanted it to. Anyway. I have an 85 with a 3" rough country lift and I am running 31x10.5's currently but I would like to run 33's. I still have the stock fender flares and I would like to keep those if possible. What triming/other mods will I need to do to be able to run these tires with out rubbing. I do not do a ton of off roading so my suspenson rarely sees full flex, but I would like them to not rub in normal driving and mild off roading (i.e. the beach). Thanks for any advice.
Also will I be fine with a stock gear ratio in the rear running 33's.
cardana24 is offline   Reply With Quote
Old 04-03-2008, 04:02 PM   #2
mall_crawler
Bodywork by the Dewalt Brothers.
[B][COLOR="Navy"][ ] lllllllllll [ ][/COLOR][/B]
The Trail Never Ends.....
mall_crawler is offline   Reply With Quote
Old 04-03-2008, 04:07 PM   #3
XJLI
1993 XJ Cherokee
This man has his head on straight. I'd reckon he has many degrees from various universities all over the world.
Factory Four Link
XJLI is offline   Reply With Quote
Old 04-03-2008, 04:18 PM   #4
dudeinatj
I run 33s on 2.25" of lift. I trimmed up front, out back, cut and folded the pinch seam inside the front fender. The only spot I rub for now is on the inside of the fender. This is only when I am turned at full lock and going over a decent sized bump while the sway bar is still connected. A BFH will take care of that.
dudeinatj is online now   Reply With Quote
Old 04-03-2008, 04:32 PM   #5
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
33x10.5s on ~3" of OME/JKS lift:
Trim and bumpstop the bejabbers out of your Jeep and there's no problems. You can reattache your flares, leave it flareless, or do the TJ flare thing.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote
Old 04-03-2008, 07:18 PM   #6
traljnky
1991 XJ Cherokee
Dewalt is a good option but I have found a good grinder with a cutting disc works best . I prefer no flares, it"s easier to cut more off when I mangle it. Finally a BFH can fix most all clearance problems.
traljnky is offline   Reply With Quote
Old 04-03-2008, 09:08 PM   #7
cardana24
that's the look I am going for but I would like to put my flares back on. I would really like avoid any more lift but I would like bigger tires. I am guessing 33x10.5's would be less likely to rub, and I like the look of a skinnier tire better anyway. I have been looking at the 33x10.5's that super swamper makes.
Glock Forum
