How to find audio grounding problem? - JeepForum.com
post #1 of 3 Old 06-05-2012, 04:12 PM Thread Starter
leichte
I have an 87 Laredo and recently have had some radio issues.
I was getting a soft whine when the radio was on. The whine would increase with acceleration. Normal sound was coming from the speakers but the whine was as well.
Shortly after that there was no longer sound coming from the speakers. The radio was on and working but no sound. Every so often I could get sound for a few minutes if I moved the cables/wires on the back of the head but it never lasted. I do get a dull audio sound if I touch on of the rca cables on the back of the head or when I shut the radio off but still no other sound. When the unit is on, it is dead silent.
I figure there is a grounding issue somewhere but I have no idea how to locate or identify it. Can someone give me some guidance? I'd rather not take it to a car audio place if I can help it. Electrical/audio is not my thing.
Thanks for the help!
leichte is offline
post #2 of 3 Old 06-05-2012, 08:31 PM
keepishop
1989 XJ Cherokee
Grab a multimeter and set it to ohms. Start probing ground points and wires looking for resistance to the battery negative. There should be none.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 3 Old 06-06-2012, 04:05 AM
residentg
residentg is offline
audio , radio , short , speaker , wires
No spark, can't find problem Iawr XJ Cherokee Technical Forum 5 02-21-2012 12:19 AM
Ran out of gas and now i cant find the problem! mywhitexj XJ Cherokee Technical Forum 18 06-12-2010 03:54 PM
So in solving one problem I find yet another DerMeister XJ/MJ Cherokee Non-Technical Forum 13 05-19-2010 03:43 PM
Gar!!! And I get to work to find a problem w/ the XJ... :( VisualOddity XJ Cherokee Technical Forum 4 09-21-2006 09:00 AM
cherokee audio wiring problem Cherokee98_4x4 XJ Cherokee Technical Forum 4 06-09-2006 01:03 PM
