How does the TCM (Transmission Control Module) work? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How does the TCM (Transmission Control Module) work?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 12-29-2004, 06:24 AM   #1
1BadRS
I lost OD on my 88 Jeep Limited. Its something electrical, I just don't know how this system operates.
1BadRS is offline   Reply With Quote
Unread 12-29-2004, 08:11 AM   #2
xj-xile
sounds like a solenoid, well, maybe
check out this page from the Tech FAQ sticky: http://members.fortunecity.com/90limited/
It isn't too difficult to take off the tranny oil pan, take off the filter, & get access to the solenoids & clean them (of course you'll need fresh fluid, a new filter, a new oil pan gasket). I can't say with any certainty that will fix your problem though.
There might be a way to test the solenoids, but, other than the article I linked to above, I don't know how. . . maybe someone else will chime in.
2WD '96 XJ Country 4.0 auto -- 134,000 miles
and... see my photography
xj-xile is offline   Reply With Quote
Unread 12-29-2004, 02:35 PM   #3
xj-xile
Oh, & there's more stuff on the transmission, further down in the Tech sticky:
http://www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/
includes a link to a downloadable service manual for the AW4 auto tranny (somewhere on Pirate4x4.com)
Unread 12-29-2004, 02:54 PM   #4
1BadRS
thanks for the links, hopefully I can figure this out
Unread 12-29-2004, 04:02 PM   #5
Fiber Effects
k
hopefully you dont have to pull the pan ,but its not a bad job
maybe check the trottle position sensor ,,and the crank shaft position sensor(is tight) ,,I would say check and clean all oily conections, ???????????????
[URL=http://www.fibereffects.com]www.Fibereffects.com[/URL]
Home of the [URL=http://www.fibereffects.com]Jeep Rocket Scoop[/URL]
1989 CHEROKEE LOREDO 4X4 2 door.. 3"bb
1996 s/10 blazer rear springs,,,grand front coils 1 3/4" spacers,(half "=1/2"} tcase washer drop,...4 gauge alt.wire.,,3" warm air intake ,,,Around 31" yocohamas ..16" aluminium chrome wheels,,1996 boster upgrade,sythetic diffs,,,closed to open GDI radiator upgrade,,,remote start and door locks,,
..,smiles
Fiber Effects is offline   Reply With Quote
