How does this happen? - JeepForum.com
post #1 of 13 Old 05-07-2013, 08:38 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Front axle
1990 Renix XJ 'Rusty Blue'
4.5" Procomp
31" Copper STT
Life begins at the end of your comfort zone
MuddSnapper is offline
post #2 of 13 Old 05-08-2013, 10:49 AM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
Are you talking about the marks on the plate behind the pinion gear?
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #3 of 13 Old 05-08-2013, 11:05 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Original stock gears, or replacement gears ?
CJ7-Tim is offline
post #4 of 13 Old 05-08-2013, 11:39 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I'm getting old.The pics weren't big enough.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #5 of 13 Old 05-08-2013, 12:24 PM
Diamond-x
1991 XJ Cherokee
You're gonna need to provide a little more info.
Was there any schrapnel or excessive grit in the diff? Was the pinion excessively loose? Was it like that when you installed it?
Look for a large chunk of something in the nooks and crannys of the diff.
Judging by the large pic (kudos for actually putting it in focus) it looks like something contacted the plate over-and-over, possibly the pinion.
But were gonna need more info to diagnose.
Diamond-x is offline
post #6 of 13 Old 05-09-2013, 12:49 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
90 xj stock Dana 30, as far as i know stock gears. Bought it for 900 in Feb. with a 4 in lift and 31's. No grit, fluid looked pretty new though. 241 t case with slack in the chain, shaft turns more than it should when you trust it by hand. I've been having this gnarly shake and growl at low speeds, worse when braking to a stop. Opened her up cleaned her real good, even took the front shady out and it might gave helped but not a noticeable difference. Anything else you need?
Would bad shaft seals cause this? Might have to take a video..
4.5" Procomp
31" Copper STT
post #7 of 13 Old 05-09-2013, 05:00 PM
CJ7-Tim
CJ7-Tim's Avatar
Probably a sloppy pinion bearing. Any play in the axle yoke ?
CJ7-Tim is offline
post #8 of 13 Old 05-09-2013, 05:03 PM Thread Starter
MuddSnapper
1990 XJ Cherokee
Only slightly front to back. Maybe a few thousandths? It is wet around the yoke like it was leaking at one point but my driveway only does spits of brake fluid from a leaking abs hose..
4.5" Procomp
31" Copper STT
post #9 of 13 Old 05-10-2013, 02:15 PM
Diamond-x
1991 XJ Cherokee
^ this
post #10 of 13 Old 05-11-2013, 08:05 AM
AZ Jeff
2014 JK Wrangler
There should NEVER be any axial play in the pinion when installed correctly.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #11 of 13 Old 05-11-2013, 08:59 AM Thread Starter
MuddSnapper
1990 XJ Cherokee
OK. I didnt install a new one yet but I will keep that in mind. On the pass side I think my u joint is shot. The shaft slides in and out a decent amount. Could that be from the C clip breaking or the U joint
4.5" Procomp
31" Copper STT
post #12 of 13 Old 05-11-2013, 09:23 AM
98muddyjeep
The front axles dont use c clips to hold them in,the unit bearings at the wheel hold the front axles in and no it wouldnt cause that,I have seen some awful bad u joints in my time with no internal damage.
post #13 of 13 Old 05-11-2013, 09:27 AM
CJ7-Tim
CJ7-Tim's Avatar
Somebody with experience needs to see inside the diff and feel for any pinion play. You need to take you Jeep to a trusted and skilled mechanic for a proper diagnostic inspection of the differential.
CJ7-Tim is offline
