How do you make barpin eliminators?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
I will be doing a buget boost soon and will be removing rear sway bar. I've seen how you can use the sway bar end links to make BPE's. How do I make some for the front? Ya, I know, JKS. Money is tight right now, hence the "budget" part of the boost. Any sugestions would be awesome. I did a search but found very little. Thanks
#2 |
Little Red Menace
It would be pretty hard to conver the rear sway bar link mounts into front BPE's. The way the holes are set up of the rear links, it would rotate the shock eyelet 90* and completely change the cycle of the shock travel. IMO the better bet would be a set of these:
http://www.lunghd.com/Tech_Articles/Suspension_Steering_Axles_and_Brakes/Shock_Stud_Extensions.htm and glue a hockey puck inside each spring perch to limit travel on the downward cyle of the shock.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#3 |
Thats good to know. I already bought tires, but those were in the budget for this summer. I got shocks too. Those weren't in the budget, but since I have 100,000 miles and mine are stock, I figured it wasn't a waste of money. www.rocklizardfabrications.com has write-up of using the rear sway bar links. I figured I could do something for the front too while I was at it.
#4 |
Vendor
Just go to Lowes and buy some 1.5"x1.5"x1/8" angle iron. Cut, drill, and grind to fit. Works for front and rear, and doesn't turn the bushings 90* like using the rear shock mounts does.
![]() FYI: the mounting bolt spacing is different front to back, so BPE's for the front won't fit the rear, and vice-versa.
Jason West - Jeepin.com | JeepinOutfitters.com '95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc. '09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp '00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
#5 | |
Did you use a sleeve in the bushing?
1995 Cherokee 2dr Sport, 4.0, 5spd, NP231, RE 3.5"AAL, Carquest HD Coils, 31" Kumho MTs Finishing up Phase 1 of Lift My Jeep's Web Page |
#6 |
Vendor
I think it was like a 1/2" or 9/16" DIA bolt. I used one of the steel sleeves that came with the shocks, and found a bolt that fit it.
#7 |
Thanks guys. I'm on nights so I've been sleeping. Looking at JKS's, I was thinking something complicated. I have a habit of complicating things. That looks simple enough even I could do it!Thanks for the help.
#8 | |
The Post man
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#9 |
Old thread I know, came up in another discussion.
What is the advantage?
1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
#10 |
Vendor
advantage is not having to deal with those PITA barpins.
#11 |
And alot more shocks come with out the BPE's so more choices
88 XJ Red | 5" of lift | Custom Bumpers | Black Rockcrawlers with 35x12.50 BFG MT's | Custom Rock Rails | Homebrewed OBA | Custom Roof Rack Loaded | Tube Doors | Play 4x4Country.CLICK HERE |
#12 |
sorry to bring up this old topic. but if my current shock have the bar pin things, would i still be able to make them work. the pins ends are bigger then the hole in the bushing so how would i get them out..thanks
#13 |
Little Red Menace
Lube them up and hammer them out. That's what I did when I made the same style BPE's. I didn't have the sleeves, so I just used a set og bolts that were the same diameter (a tad bigger actually) and drilled the holes for that.
#14 | |
1989 XJ
4.0 / AW4 / 242 / RE 5.5" 30 Front: Chromo Shafts/Joints/4.88's. 44 Rear: Aussie/Crown Vic Disks/4.88's |
#15 |
I just took the grinder to one end, then sprayed them with PB Blaster and they slide right out.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
