How do you install shims? - JeepForum.com
post #1 of 8 Old 12-08-2005, 10:02 AM Thread Starter
Xride
I have a pair of 2.5 degree shims that I wanted to use with my 3" EMU lift, but how do you install them?
I know they go under the spring to tilt the axel so the ds is straighter.
and i figure that the little nub on the bottom of the spring goes into the hole in the middle, but then that little nub doesnt go into the hole on the leaf perch on the axel...
I dont get it. am I missing something?
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #2 of 8 Old 12-08-2005, 10:05 AM
dakotus
dakotus's Avatar
you need to remove the bolt (and that nub) once that center bolt is removed, you can attach the shim to the leaves, and then reattach the bolt. The shims should have came with longer center bolts to accomodate for the added thickness of the shim.
1999 Cherokee Sport
dakotus is offline
post #3 of 8 Old 12-08-2005, 10:06 AM
fryed_1
I drilled mine out to fit the nub
'94 XJ - 8" Long arms, 9" rear, 35's
'89 Waggy
'48 Willys
fryed_1 is offline
post #4 of 8 Old 12-08-2005, 10:13 AM Thread Starter
Xride
It has longer bolts, althought the one in the emu leafs are pretty long already.
I'll have to have a look again because it seemed to me that the hole in the shim was bigger then the nub.
Xride is offline
post #5 of 8 Old 12-08-2005, 10:15 AM Thread Starter
Xride
wouldnt that mean the leaf isnt secured as well because the nub cant fit into the hole on the axel?
Xride is offline
post #6 of 8 Old 12-08-2005, 10:18 AM
wipedawg
wipedawg's Avatar
It needs to fit in the hole on the mounting plate... or dont put it on if it doesn't. Your bolt should fit in there though if its the right one... oh.. and whats an "axel" is that axel foley i hear?
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #7 of 8 Old 12-08-2005, 10:23 AM Thread Starter
Xride
axle
left hand is faster sometimes, I type in word too much, and it autocorrects as I go, so I dont notice most of the time.
Xride is offline
post #8 of 8 Old 12-08-2005, 10:54 AM
fryed_1
What I did was use a 1/2" steel block. I got it with an extra tall and wide nub that would sit into the spring pad. I drilled the shim out to fit under the block's nub, then the spring tab sat into the hole on the block. I drilled out the new spring pad slightly to fit securely the block's nub. They are tight enough I needed a hammer to press them onto the springpad and the leaf onto the block. Haven't had a single problem with it yet.
So in short, the nub on the 1/2 block is taller than the shim. So the nub sticks through the shim and seats into the spring perch.
'89 Waggy
'48 Willys
fryed_1 is offline
How To Install New Center Pins For Shims? allibaster XJ Cherokee Technical Forum 8 09-12-2009 01:29 PM
Which way to install shims ksander XJ Cherokee Technical Forum 2 12-05-2008 04:34 PM
Should I install axle shims without an SYE? Magickman XJ Cherokee Technical Forum 13 08-19-2008 04:27 PM
shims georgesxj XJ Cherokee Technical Forum 1 10-09-2006 11:50 PM
how to install shims? mps XJ Cherokee Technical Forum 3 05-14-2005 12:54 PM
