How do you get a crank position sensor out?
#1 | |
www.lp.org
How do you get the crank position sensor out of a 4.0 XJ with auto trans? It looks like the easiest route is from the bottom, but I've tried every wrench and socket combination that I can come up with and I just don't have the room to move.
All help is greatly appreciated.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? " Roger Waters |
#2 |
I got mine out wile the intake was off but I would guess that using a 2-3 ft 3/8 entension and maybe a swivel socket you should be able to access it from the back of the transmission. Other wise use a floor jack under the transfer and lower the transfer to get a little tilt while using the same 3/8 socket set up. The should get the bolts out and then you might have to reach from the top to pull the sensor out. Use some masking tape across the top of the socket then push the bolt into the socket to hold the bolt in place when you want to reassemble.
Mods 2006 Jeep Wrangler X, 4.0 4:11 gears '90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank A/C Conversion/Home Built Roof Rack/K&N Box Filter Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer Jeep Pic's |
#3 |
www.lp.org
As much as I hate to do it, I'm having the beast towed to the dealership. A lot of my sensors' grounds are testing at 11 ohms rather than the specified 5 ohms. The wiring tests okay, no shorts, good continuity. I hope they can figure it out for me. I'm getting tired of having a rig that runs like crap. I haven't been in the mud at all this winter and I don't plan on going all summer without seeing rocks.
#4 | |
The secret is a "wobbler"...aka "universal joint adapter" for your socket wrench. I used that, plus a 4" extension to get mine out/in.
CURRENT - ordered 10/26, home 1/14 2008 JK Unlimited,3.8L,6-spd,limited slip,dual tops,tow pkg,all power SOLD 1999 XJ 4.0L,AX15,NP231,D30HP,C8.25 STOLEN 1993 XJ 4.0L,AW4 ,NP231,D30HP,C8.25:::C4X4 THB:GDI 3row:K&N:JKS QD: Dynomax#17340:MagnaflowCat#23221:Surco 45x60 |
#5 |
www.lp.org
Yeah, I just don't have the room to move the ratchet. I'm even using a 1/4" socket set. Its gonna' be the dealers headache now. I just hope they know how to deal with all of the bolt on goodies, MSD crap, etc. It looks like an air ratchet would be very useful in there though.
#6 |
I use a long 1/4" drive extension with a 10mm (I think) swivel socket on the end. I go at it from the bottom.
1997 VW Jetta - Daily Beater <---Totaled, seeking replacement DD 2004 GMC Envoy - Wife's Ride |
#7 |
i just did it today and i used about 12 inches of extension and a swivel and it came out easy from the bottom
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
