How do I tell what lift I have in the back? - JeepForum.com
post #1 of 5 Old 11-30-2012, 08:51 AM Thread Starter
who_datjeep
The PO told me it had a 4 inch rough country lift but somebody else told me it had a 4.5 inch lift. The latter told me that many vehicles have more lift in the back then in the front. Is this true? If I get some new leafs from my local four wheel parts and the truck gets more lift in the back than in the front is there anything I can do to even out the level?
who_datjeep is offline
post #2 of 5 Old 11-30-2012, 09:09 AM
ltrail
1984 XJ Cherokee
I'm assuming this is a full leaf pack? depending on the age you may be able to read the numbers on them. I bought a used RE 4.5", the part numbers as well as the RE stamp were evident and I found it was just that.
Second question would be why do you need new leafs?
And if the 1/2" is so noticeable then you can get a spacer for front or shackles with adjustments.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #3 of 5 Old 11-30-2012, 10:37 AM
AustinTexasXJ
1987 MJ Comanche
if its a RC lift, then it will be a 4.5". they didnt make a 4" just 3" / 4.5" / 6.5".
that will probably help you.
plus just go with a 4.5" full packs and then if you need to get 3/4 spacers for the front of the XJ. the rear is gonna sit higher anyhow
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #4 of 5 Old 11-30-2012, 12:32 PM Thread Starter
who_datjeep
It is a full leaf pack. The arch in the leafs are not the same. Every time I go over a bump the tires rub the flares. Every where I go squeak squeak squeak all the time even when I get in and out of the vehicle. I know leaf springs are supposed to last a long time but there must have been something wrong with these.
Thanks for the input!
post #5 of 5 Old 11-30-2012, 12:33 PM Thread Starter
who_datjeep
Thanks. It did.
how much , leaf springs , lift , rear , suspension
