How do I tell if my differential is limited slip? - JeepForum.com
post #1 of 11 Old 08-17-2010, 12:59 PM Thread Starter
spenceuiuc
I am in the process of getting a fullsize spare for my 1998 XJ Sport with Command Trac (right now, I just have the donut-spare).
Currently, it has 16" rims on it from a 2000 XJ, which are expensive to buy. I can get a 15" steel wheel for cheap, but I don't want to toast my differential if it is limited slip with the different tire sizes.
So, how do I tell if I have a limited slip differential or not?
Thanks!
spenceuiuc is offline
post #2 of 11 Old 08-17-2010, 01:04 PM
XjChris843
1997 XJ Cherokee
take the diff cover off and look
97' XJ sport 4.0 - 8 inches of lift - full rusty skids - arb rear aussie front - 4.56 gears - 35X10.50 Interco Super Swamper SSRs- 16'' Cragar Soft 8 rims - wilderness roof rack - rustys steering box brace - rustys roll bar - rustys short arm intake - hack n tap SYE - YJ NP231J - trans cooler - tons of other stuff
XjChris843 is offline
post #3 of 11 Old 08-17-2010, 01:17 PM
Diamond-x
1991 XJ Cherokee
Look for what? What is the distinguishing factor?
Diamond-x is offline
post #4 of 11 Old 08-17-2010, 01:19 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
a limited slip looks like this:
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #5 of 11 Old 08-17-2010, 02:01 PM
XjChris843
1997 XJ Cherokee
this is what an open diff should look like, i believe this is a D35.
post #6 of 11 Old 08-17-2010, 02:07 PM
XjChris843
1997 XJ Cherokee
lol...well thats how it should look its its an open diff, not counting the broken teeth on the spider gears
post #7 of 11 Old 08-17-2010, 02:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
In a safe and wide open area, do a burn out on grass, dirt/sand, or snow. A Limited Slip will leave two tire stripes, an open differential will leave just one.
Or, open the diff and look inside.
As long as all 4 tires are the same size, it doesn't matter to the Limited Slip what the tire size is.
Open on the left and Limited Slip on the right -
CJ7-Tim is offline
post #8 of 11 Old 08-17-2010, 02:52 PM
Saudade
1988 XJ Cherokee
There should be a tag under one of the diff bolts at says to use a friction modifier (or LSD additive).
Here's my D35...
Saudade is offline
post #9 of 11 Old 08-17-2010, 03:14 PM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by Saudade View Post
There should be a tag under one of the diff bolts .......
I laughed so hard, coffee came out my nose. In the real world where rust lives and breathes, those tags are long gone.
CJ7-Tim is offline
post #10 of 11 Old 08-17-2010, 03:31 PM
Saudade
1988 XJ Cherokee
LOL... what was I thinking?
(Yes, the tag's still under my turdy-5)
Saudade is offline
post #11 of 11 Old 08-17-2010, 03:41 PM
Kettles
A few things, first off, your talking wheel size not tire size.
Secondly, your just talking about the spare tire.. More than likely the spare wouldn't even be used, so its size matching the others is not as important (hence the donut spare), A fullsize spare in the jeep world is usually because if you have a flat on the trail you want to beable to drive out, where a donut would struggle being its so small. So any close tire size would be fine, so long as you don't use it full time on the street. I view my spare as a way to get home or to a shop, not as another tire to use (and i have a full spare).
Thirdly, if you had an LSD out back I would bet money that it came with a full size spare. If it had LSD but no full size spare, then they must not have been worried about tire size differences when using the donut spare, so I wouldn't be either.
And more helpful probably.. If the 16" wheels on your jeep (from a limited) have the factory size tires on them, and the 15" wheel your looking at was from a cherokee (or wrangler I think) and it has the factory size tire on it then I would bet the tires are the same OD.
The factory size was 225/75/15, or for a limited I think 225/70/16. Those are for all intensive purposes the same size tire, just a different wheel diamiter.
As for how do I I find out about LSD. You can look for the tag on a bolt, you can look in the glovebox for a sticker, you can email jeep for your build sheet, or you can open the diff and look.
Burnout tests can be inconclusive as it is possible to have a 2 wheel burnout with out LSD and a 1 wheel burnout with it. You can also jack up the back of the jeep and turn one tire, if the other turns the same direction, LSD (you need to be in neutral for this test).
Good Luck!
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
differential , limited slip , spare tire
Does a 98 XJ 4.0 Have limited slip???? chevycowboy250x XJ Cherokee Technical Forum 15 09-21-2008 12:46 AM
8.25 limited slip CLB XJ Cherokee Technical Forum 8 05-20-2004 12:42 PM
limited slip differential dawnme6a XJ Cherokee Technical Forum 4 07-30-2002 05:20 PM
Limited Slip on a 94 nickw252 XJ Cherokee Technical Forum 2 05-05-2002 09:56 PM
Limited Slip Differential Chero Roma XJ Cherokee Technical Forum 3 01-07-2002 02:14 AM
