How do I tell if I have a limited slip differential? - Page 2 - JeepForum.com
 1Likes
post #16 of 21 Old 11-30-2012, 09:50 AM
foggybottombob
the only way to know what differential you have is to take off the cover and look at it. The spin test only works for certain types of differentials which are not worn out.
foggybottombob is offline
post #17 of 21 Old 11-30-2012, 02:02 PM Thread Starter
who_datjeep
Makes sense. What weight and how much oil do I need for Dana 35?
who_datjeep is offline
post #18 of 21 Old 11-30-2012, 03:04 PM
foggybottombob
Taken directly from the YJ FAQ (frequently asked questions):
What fluids do I use and how much do I put in my Jeep?
*Axles:
- Gear oil - 80 weight for light duty and normally cooler climates - 90w120 weight for heavy duty and normally warmer climates Note: Some rear axles are equiped with factory posi - a limited slip additive must be put in with the gear oil to extend and protect the limited slip action
Dana 30 = 2.5 pints
Dana 35 = 3.5 pints
Dana 44 = 4.0 pints
I use 75w90 as I recall.
post #19 of 21 Old 01-22-2016, 01:14 PM
aei_vd
Hi guys,
Isn't there any online resource in which I can check by VIN number if my ZJ has the LSD or not?
aei_vd is offline
post #20 of 21 Old 01-22-2016, 01:15 PM
aei_vd
Hi guys,
aei_vd is offline
post #21 of 21 Old 01-23-2016, 10:19 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
You can get a build sheet from the manufacturer that will tell you whether or not your vehicle came with a limited slip rear from the factory. Of course, that doesn't mean that it's working or even that it's still installed - you have to check that yourself. Friction modifier is cheap, and adding some, or spending a couple of extra bucks on fluid that includes it already won't have any effect on your standard open differential, if that's what you have.
- Justin
1992 Cherokee Laredo - all stock, DD. Needs some minor rust repair, then on to the mods!
1996 Cherokee Classic - 3.5" lift / 31.0x10.5 Mastercraft Courser CTs / Warn XD9000i - Stripped for parts / junked :(
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
differential , limited slip , rear axle , sticker , tag
