How do I start without a key? - JeepForum.com
post #1 of 6 Old 07-09-2010, 01:57 PM Thread Starter
That1guy
That1guy's Avatar
2007 WK
I'm not trying to steal anything. We have a parts jeep that we got a few months ago and it ran and drove when we parked it. We are trying to sell the motor and would like to get it running for people to hear. Some how the key has disapeared. We would really to start it. Any suggestions?
It's on a 95
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #2 of 6 Old 07-09-2010, 02:02 PM
Drew M
1997 XJ Cherokee
If it is a parts Jeep and you don't care about the steering column lock a big-*** screwdriver should suffice for a key.
Option B would be to remove the ignition switch and turn it by hand.
1997 XJ 4.0L | 1998 BMW M3/4
Drew M is offline
post #3 of 6 Old 07-09-2010, 05:53 PM
scott_jeep
Yeah, removing the ignition cylinder and then pushing the little nub by hand would be might first choice. That way you know for sure you can turn it back off again.
scott_jeep is offline
post #4 of 6 Old 07-09-2010, 06:46 PM
justanotherjpr
If you can't turn it manually, the ignition should have a few wires:
Constant hot
Ignition
Accessory
Start
Twist the constant hot and the ignition together - that will send power to the coil, ECU, ect. Touch the start wire to the newly twisted wires and the starter will turn. Remove the start wire when the engine is started. Disconnect the wires to stop the motor.
You'll have to take apart/break the column to get to these wires.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #5 of 6 Old 07-13-2010, 06:43 PM Thread Starter
That1guy
That1guy's Avatar
2007 WK
Ok sounds good. Anyone have a wiring diagram of the column?
That1guy is offline
post #6 of 6 Old 07-13-2010, 09:01 PM
KINGJB
google might know
Build Thread:
KINGJB is offline
No start......Replaced the Crank Sensor and still no start, Whats UP? batilzown XJ Cherokee Technical Forum 3 02-17-2010 12:50 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 08:56 AM
Hard Start, No Start, Rough Idle Hillbillydeluxe XJ Cherokee Technical Forum 11 09-19-2008 12:11 PM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 08:18 PM
Eh.. start? no start? roll the dice? jiggle the cable? UnderDog! XJ Cherokee Technical Forum 6 05-25-2006 09:14 AM
