How do I adjust my transmission shifter linkage? - JeepForum.com
post #1 of 7 Old 04-03-2009, 10:48 AM Thread Starter
Mike94ZLT1
I've been doing some research on my shifting issue, and I think an improperly adjusted shifter cable may be part of my problem (especially since my problem started when the shifter was SLAMMED from park to drive by one of my idiot friends) Anyways, I have a 99 4.0 with an auto, how do I adjust it? Thanks!
2009 Jeep Grand Cherokee Laredo 4.7, 4WD, Stock for now
2006 Ford E-150 4.6, RWD, "The Happy Bus"
1999 Corvette FRC 383 LS6 stroker, built drivetrain, full suspension, not much left that's stock
1937 Ford 5 Window Coupe 327 SBC, M-22 4 speed, etc..
Mike94ZLT1 is offline
post #2 of 7 Old 04-03-2009, 10:58 AM
skullver
Tarpitz
1991 XJ Cherokee
the shift linkage attaches to the trans on the driver side, you can get under there and have a buddy shift it and see how off it is. there is also a way to adjust it with a voltmeter as outlined in the factory service manual
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #3 of 7 Old 04-03-2009, 01:14 PM Thread Starter
Mike94ZLT1
Is it something that needs to be tightened or what? I've never messed with one, so I have no idea what I'm doing. I'm quite capable of doing the work, I am just not familiar with jeeps or automatic transmissions.
post #4 of 7 Old 04-03-2009, 09:49 PM Thread Starter
Mike94ZLT1
Anyone?
post #5 of 7 Old 07-13-2010, 08:05 PM
VRFinfrock
Linkage Adjustment
I also have the same problem and have been able to hit the shifter into park with the palm of my hand if I am on level ground. If I am not level and the vehicle has rolled forward, I will need to get out, open the rear hatch and bounce the shocks. This always works. I would just as soon find out how to adjust the linkage. If I figure it out, I'll drop you a line.
VRFinfrock is offline
post #6 of 7 Old 11-08-2010, 12:51 PM
7urtle
2008 KK Liberty
bump.
hit it with a hammer
-1UMF a really slow build. bruised and never left the street
WTB: rear bumper/tire carrier,31" tires,armor
7urtle is offline
post #7 of 7 Old 11-08-2010, 04:07 PM
AZ Jeff
2014 JK Wrangler
Here you go: http://www.jeepforum.com/forum/f11/a...-park-1125788/
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
how to adjust 1995 auto trans linkage dirtdad XJ Cherokee Technical Forum 1 08-09-2009 09:40 AM
Pic Request....tcase shifter linkage anybody? Moose_God XJ Cherokee Technical Forum 1 12-30-2007 07:29 PM
NP231 TC Shifter Linkage LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 7 10-25-2007 07:22 PM
4X4 Shifter Linkage 87 Cherokee Larado FrankEllijay XJ Cherokee Technical Forum 1 10-06-2005 12:13 AM
Stuck in PT.....Adjust T-Case linkage... ddoffroad XJ Cherokee Technical Forum 5 06-26-2004 10:18 PM
