How do change a cam sensor on 1999 jeep grand cherokee - JeepForum.com
post #1 of 2 Old 05-08-2010, 12:40 PM Thread Starter
lowside
I bought a cam sensor on a 1999 jeep grand engine size 4.0. Can I just change the two bolts and change the sensor, Because I put an new sensor on and still no spark. Some one said that # 1cyl has to be on tdc and then it has to be aligned with the right size pin?
lowside is offline
post #2 of 2 Old 05-08-2010, 01:04 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Are you working on a 6 cyl. or 8 cyl.? You should also post this question here since you have a WJ and this is the XJ section. ZJ & WJ Technical Forum - JeepForum.com
xjfever is offline
1999 4.0L Jeep Cherokee Radiator Fluid Change tkdan235 XJ Cherokee Technical Forum 9 04-26-2016 06:22 AM
How do you get at a 4.7L 99 Jeep Grand Cherokee Limited 4 crankshaft position sensor SierraNev XJ Cherokee Technical Forum 2 12-22-2010 02:33 PM
1999 Jeep Cherokee Battery Temperture Sensor ridebmxfbm XJ Cherokee Technical Forum 5 03-28-2010 09:17 PM
1999 Jeep Grand Cherokee manual Gonz65302 XJ Cherokee Technical Forum 2 07-01-2009 01:30 AM
97 Cherokee Crank Sensor Change 52pu XJ Cherokee Technical Forum 3 12-11-2002 12:01 PM
