How to determine what axles I have - JeepForum.com
post #1 of 10 Old 01-21-2010, 09:50 AM Thread Starter
stockli
1989 XJ Cherokee
I was hoping you guys could tell me what axles are on my jeep or how to find out what axles are one there.
I have a 1989 Cherokee Limited.
I am going to the bone yards this weekend and will be tearing parts off junkers like there is no tomorrow!
thanks for the help!
stockli is offline
post #2 of 10 Old 01-21-2010, 09:56 AM
Agility
1997 XJ Cherokee
check this chart against your rig
you should also check the wiki to see what the options were that year, sometimes people have a hard time identifying these just by the pictures
Agility is offline
post #3 of 10 Old 01-21-2010, 10:15 AM
RedZeppelinXJ
assuming that your axles are stock you will have the High Pinion Dana 30 front axle, then either the Dana 35 rearend (most common in '89) or the highly coveted Dana 44 (which is a much better axle and an option on some but not all tow package cherokees from '87-89)
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #4 of 10 Old 01-25-2010, 01:16 PM
rjjk45
1988 XJ Cherokee
My 1988 Jeep had a tag on the rear axle housing with numbers on it.
I called dealer and they confirmed Dana 35
rjjk45 is offline
post #5 of 10 Old 01-25-2010, 05:11 PM
bootht99
1990 XJ Cherokee
are the 8.25's any better than the dana35's? mine looks more like the chrysler axles and it has the rubber filler plug.
Is it considered "stuck" if you get yourself out?
PURPLE JEEP CLUB MEMBER #10
bootht99 is offline
post #6 of 10 Old 01-25-2010, 05:19 PM
That1guy
That1guy's Avatar
2007 WK
Yes and No. The chrysler 8.25 is stronger than the 35, but there are two versions of the axle. They are 27 spline axles up in till mid 96 when they decided to switch to 29 spline. The 27 is better than the 35 by a little, but the 29 is a decent bit stronger than the 35.
You can get the shafts for a 29 spline xj 8.25 and get a 29 spline locker or set of spider gears and convert yours to the stronger version.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #7 of 10 Old 01-25-2010, 07:08 PM
shayne99xj
well all xjs have either a dana 30 high or low pinion, but the rear is either a dana 35 or chrysler 8.25. if the jeep has anti lock breaks its a dana 35, if it doesnt have anti lock breaks its the chrysler 8.25
shayne99xj is offline
post #8 of 10 Old 01-25-2010, 07:32 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
This is not true. The d35 was offered with or without ABS. And the 8.25 wasn't offered on the OP's model.
xjfever is offline
post #9 of 10 Old 01-25-2010, 07:35 PM
GeologistFelix
1990 XJ Cherokee
Wrong!
1984-1986 XJs all had D35 rear ends. 1987-89 had either the D35 or the D44 (rare, only found on some XJs with the tow package). 1990 only had D35 rear axles. Then, 91-95 had either the D35 or 27-spline 8.25". 96 had the same, though supposedly some of the later 8.25 axles in 96 were 29-spline. 97+ XJs had either a 29-spline 8.25" axle or a D35.
All XJs with ABS have D35 rear axles. Most 91+ non-ABS XJs have an 8.25" rear axle, but there were some with D35 rear ends too.
Since you have an 89, you've got either a D35 or a D44, and it's pretty much guaranteed to be a D35 with that rubber fill plug.
GeologistFelix is offline
post #10 of 10 Old 01-25-2010, 08:57 PM
RedZeppelinXJ
booth, assuming you have the factory axle for ur '90 it is the D35, but it may have been upgraded at some point, the D35 has a more rounded diff cover, while the C8.25 has a flatter top and bottom, another give away is the rolled edge on the C8.25 (see the picture a few posts up)
and yes the C8.25 is stronger, the 27spline ('91-96) is a slight upgrade, but the 29 spline ('97+) is a quite a bit stronger and is a noticeable upgrade
how to determine what gears i have? turbophein XJ Cherokee Technical Forum 2 02-07-2008 05:47 PM
how do i determine lift? txjeep103 XJ Cherokee Technical Forum 2 12-12-2006 12:00 PM
How do I determine if I have ABS or not. MageXX9 XJ Cherokee Technical Forum 15 12-08-2006 05:06 PM
How to determine ABS. Glazzed XJ Cherokee Technical Forum 11 05-31-2006 04:12 PM
How to determine gearing... XJ-NoDough XJ Cherokee Technical Forum 2 01-28-2006 07:21 PM
