how to check ball joints? - JeepForum.com
post #1 of 15 Old 12-29-2008, 12:48 AM Thread Starter
compfreak530
im still a newb to suspension all together. but how do i check if my ball joints are going bad? my jeep starts feeling very odd at speeds in excess of 55Mph.. i get intermediate vibs that come and go very frequently. my jeep also drifts slightly. <while driving down the road i notice it will go were it wants. but half the time it will drive straight. my jeep is bone stock but im kind of clueless. i know in while using 4h or 4lo my front end feels to be binding up so im thinking i have something major wrong, what all should i check?
compfreak530 is offline
post #2 of 15 Old 12-29-2008, 12:53 AM
mike243
might be a wheel bearing.
mike243 is offline
post #3 of 15 Old 12-29-2008, 06:43 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Would be a good idea to get your XJ on a hoist and have somebody familiar with front end/steering components perform a thorough inspection of parts for wear/play. There are really a lot of things that can contribute.
It's possible that you need a front end alignment as well but hold off on that until you inspect all parts as there are certain situations which would require an alignment after replacement of that hardware. Good Luck!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 15 Old 12-29-2008, 07:37 AM Thread Starter
compfreak530
i have access to a lift, but i dont know anyone that is really familiar the front end, could someone perhaps give me a check list of things to check? i`ll jsut search on how to check the items.. thanks
post #5 of 15 Old 12-29-2008, 08:41 AM
Jeds Sr.
Do you feel the vibs in the seat or the steering wheel? Sounds like your tires are out of balance.
On the front check the tie rod ends and the track bar. Have someone lightly turn the steering wheel right and left while you look for play in each part.
Jeds Sr. is offline
post #6 of 15 Old 12-29-2008, 09:32 AM Thread Starter
compfreak530
i feel vibes thro my whole xj. enough to vibrate a cell phone off my dash, its not the death wobble just vibes, i know its something with the front end as i hear a clunkish sound comming from the driver side tire while turning either way, i belive that to be the shock tho
post #7 of 15 Old 12-29-2008, 10:03 AM
tangofox007
Originally Posted by compfreak530 View Post
i know in while using 4h or 4lo my front end feels to be binding up...
On dry pavement, that is perfectly normal. It's also why 4WD should not be used on dry pavement.
tangofox007 is offline
post #8 of 15 Old 12-29-2008, 10:04 AM
lcarney91
Jack up one front wheel at a time, until the tire is 3-4" off the ground. Take a pry tool of your choice (pry bar, crow bar, jack handle, pipe, etc.) and pry upward on the bottom of the tire. Check for vertical movement of the tire/wheel. Too much movement is an indicator of excessive ball joint wear.
Now, with the same wheel/tire, place hands at 3 and 9 o'clock positions. Move tire from side to side, and check for excessive movement. There should be some free movement when doing this, but not too much. This checks steering/ hub bearing wear. You may want to have a friend do this while you watch the steering linkage. Again, some movement is expected, but not too much.
1999 XJ.....
Stock, with some intake/exhaust work
"The ol' family truckster"
lcarney91 is offline
post #9 of 15 Old 12-29-2008, 10:13 AM Thread Starter
compfreak530
this was in snowy icy roads, the jeep also pulls very hard to the driver side, but not while in 4 full, has the np242.
thank you lcarney91, i`ll try that today
post #10 of 15 Old 12-29-2008, 10:27 AM
lcarney91
The acceptable amount of movement is debatable, that's why i left it out. Some say you shouldn't have any vertical movement, but the FSM gives a different spec. I'll let the experts jump in here.
1999 XJ.....
post #11 of 15 Old 12-29-2008, 11:21 PM
onlyinaYJ
i would just smash the front end and have insurance comp. fix it lol.
onlyinaYJ is offline
post #12 of 15 Old 12-29-2008, 11:54 PM Thread Starter
compfreak530
umm. no thanks. i paid 300 for my jeep and its almost perfect. no cracks in the leather, headliner looks new. new pioneer stereo,tires have 90% tread left and spare is brand new never been used, carpet has been kept up forever, no cracks in dash looks new,motor is strong to, just a few small ish problems
post #13 of 15 Old 01-08-2009, 02:51 PM
bcdale
1988 FSJ Cherokee
i have the same problem while running in two wheel , have new tires
no play play in front end seems like front end is still in 4 wheel and tach shows 1500 rpm,
and yet @ 60 mph it like its going at top speed.
should drive shaft still be turning or in 2 wheel should it disengage.?
bcdale is offline
post #14 of 15 Old 01-08-2009, 09:40 PM
jdearmitt
Yeah it will still turn.
jdearmitt is offline
post #15 of 15 Old 01-08-2009, 09:49 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
bad ball joints wont really cause a vibration. i would say that you need tires rebalanced and an alignment.
1990JEEPXJ is offline
Ball joints Arcticcat843 XJ Cherokee Technical Forum 6 04-03-2008 09:52 AM
ball joints cherokeewes XJ Cherokee Technical Forum 3 03-30-2008 04:52 PM
Ball joints tweekedknee XJ Cherokee Technical Forum 1 08-31-2006 10:10 AM
Ball Joints and ETC NYCXJ90 XJ Cherokee Technical Forum 3 07-11-2005 10:55 PM
need to replace wheel u-joints and ball joints in front 90XJGuy XJ Cherokee Technical Forum 3 05-31-2005 02:32 PM
