how to change turn signal switch on 93 xj - JeepForum.com
post #1 of 4 Old 09-09-2010, 10:44 AM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
how to change turn signalswitch on 93 xj
cant figure it out ,,, nor find it in haynes manual,,,
coalregion4x4.webs.com
JOEGUYZXJ is offline
post #2 of 4 Old 09-09-2010, 10:48 AM
Mikeand
Should be plenty of writeups on here if you search it. Also found a bunch of sites on Google for doing it...its a GM style column...pretty easy to do.
Id advice renting a steering wheel puller and a lockplate spring compressor.
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline
post #3 of 4 Old 09-09-2010, 10:54 AM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
couldnt find anything ,,,
post #4 of 4 Old 09-09-2010, 10:57 AM
Mikeand
Heres a good link with lots of info..
Jeep CJ Column and Lock Cylinder
and another..
http://www.chevyasylum.com/column/tiltcol.html
Mikeand is offline
Write Up: Replace the Turn Signal Switch on 97+ XJ the_weirdo XJ Cherokee Technical Forum 73 01-24-2017 09:59 AM
Turn signal switch/multi-function switch same thing? Strokin87 XJ Cherokee Technical Forum 15 12-15-2012 04:44 PM
Turn Signal Switch / Stalk talentjeep XJ Cherokee Technical Forum 7 02-06-2010 08:26 AM
I NEED HELP!!! Turn signal switch/stalk orangepower1987 XJ Cherokee Technical Forum 11 09-17-2009 02:28 PM
turn signal switch boise49ers XJ Cherokee Technical Forum 3 05-31-2004 11:37 PM
