how to change radiator? - JeepForum.com
post #1 of 12 Old 02-28-2008, 11:27 AM Thread Starter
medicbear
i dont have a service manual anyone know any write ups or how on how to do it? 96 with ac AT. i figure everyone says its not that hard so why pay a shop 90-120 labor plus coolant....with the money ill save i can get a decent new one vs a used one from pick and pull that i gotta hope doesnt leak
OEF Vet still serving.
2007 Sahara Unlimited Stock for now
True Story while she was driving my XJ: "Honey hold my slurpee and watch this!"-My wife
come check us out
medicbear is offline
post #2 of 12 Old 02-28-2008, 12:29 PM
95cherokee33s
Yeah its really not that hard. I am sure there is a write up somewhere on here. Basically you remove the battery, fan shroud, electric fan and the radiator cover (the top plastic piece over the radiator). Then just take the two tranny lines off and coolant hoses.
95cherokee33s is offline
post #3 of 12 Old 02-28-2008, 12:52 PM
dcorn
I did this within a month of buying my XJ because the stock piece was leaking and didn't have a single problem. I ordered a CSF 3 core, all metal radiator from DPG offroad for around $170 shipped.
I had a haynes manual handy but it really didn't help me too much. Search this forum and NAXJA for a write-up, they are definitely out there.
Basically, drain the coolant from the petcock on the passenger side of the radiator (mine was behind the turn signal under the headlight, hard as hell to get to). I just took a hose off and drained it that way. Unbolt the core support and take it out. It'll probably give you more room to take out the battery too. Take out the electric fan as well as the engine driven fan shroud. Take all the hoses and lines off. You need a fuel line tool to get the transmission line connector off. Mine took forever to me to get off. Pull the radiator straight out and reverse everything. Took me an afternoon plus a trip to autozone to the the fuel line disconnect tools.
Much more satisfying doing it myself. I've never taken my Mustang to a shop for work, I don't plan on taking my Jeep anywhere either (except maybe for the gears, but I had a friend help me do them in my driveway on the stang).
dcorn is offline
post #4 of 12 Old 02-28-2008, 12:52 PM
Jeep gal
Jeep gal is offline
post #5 of 12 Old 02-28-2008, 02:55 PM
ashoemak
I changed mine out a few weeks ago. It was pretty easy. There are a few write ups under the tech section on here that i referred to.
ashoemak is offline
post #6 of 12 Old 02-28-2008, 05:21 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I changed mine out last summer,the plastic resevoir on the end blew off. I would deff. go with a three row all metal radiator. I got mine at advance auto, cant remember exactly how much but mine ran at 210 all the time and 230 plus with air on. I put new radiator, water pump, 180 thermostat,new hoses and flushed coolant. now it runs at 175 to185 with or without air on.
xjfever is offline
post #7 of 12 Old 02-28-2008, 05:33 PM
tcc9mpl
my plastic screw blew off recently as well, does that mean i should get a new radiator? (i had the thermostat and fan clutch replaced , and coolant flushed)
Mods Surco Safari Rack 40''x60'' Baja Fogs K&N Air Filter
Audio Pioneer DEH-P7800MP headunit Infinity Ref. 311a Amp Infinity Ref. 1032w DVC Sub Rockford Fosgate 5.25'' TC120s
tcc9mpl is offline
post #8 of 12 Old 02-28-2008, 05:45 PM Thread Starter
medicbear
i noticed some say lh and some say rh drives... how do i know which one i need? and then they also state some are HD
come check us out
post #9 of 12 Old 02-28-2008, 05:48 PM
mickdawg777
1995 XJ Cherokee
lh and rh drives mean what they say. Your vehicle is left hand drive, because you're sitting in the left seat. It's true, that's what they mean by lh and rh drive.
Get the HD one. more coils.
Chris a.k.a. "Mickey"
I always manage to buy absolute junk and putting tons of $$$ in it. No such thing as a good deal.
mickdawg777 is offline
post #10 of 12 Old 02-28-2008, 06:00 PM Thread Starter
medicbear
thats what i thought was the hd would fit the same but provide extra cooling since its designed to work under more stress or higher temps
come check us out
post #11 of 12 Old 08-20-2012, 10:36 AM
evied
Why do I need to remove/disconnect the neg battery cable? I have a leak at the bottom of my radiator somewhere. I am attempting to figure out where it is but I don't know if I need to remove the cable in order to take the grill reinforcement panel off and maybe the fan shroud?
evied is offline
post #12 of 12 Old 08-20-2012, 04:42 PM
rugsucka
You need to disconnect the battery so you don't make hand-burger when you're in and around the serp belt by someone cranking the engine over, pressing the auto start etc. by accident.
I work with a fellow nicknamed fingers and another named stumpy. You don't want their nicknames too.
rugsucka is offline
1999 4.0L Jeep Cherokee Radiator Fluid Change tkdan235 XJ Cherokee Technical Forum 9 04-26-2016 06:22 AM
Radiator Spout where hose connects to radiator overflow bottle.. gregmondro XJ Cherokee Technical Forum 2 08-13-2009 08:49 PM
New radiator doesnt match old radiator Hamza07 XJ Cherokee Technical Forum 1 01-02-2009 01:24 PM
radiator fluid change on XJ Bitzorock XJ Cherokee Technical Forum 4 09-10-2008 12:14 AM
radiator/engine flush, tune up, oil change (the works) sharpie XJ Cherokee Technical Forum 4 09-18-2006 01:12 PM
