How can I tell when the torque converter locks/ unlocks? - Page 2 - JeepForum.com
post #16 of 20 Old 10-17-2008, 11:22 PM
cheapfix
1991 XJ Cherokee
Originally Posted by ehall View Post
nope, I used a scanner to read it
Scanner? You don't even have doors...
Recovering moparholic
cheapfix is offline
post #17 of 20 Old 10-18-2008, 12:24 AM
cheepjeep96
1990 XJ Cherokee
Yeah.. Does it lock up around 40-45mph though? because when i had my 96, cruising it would go into a lower rpm, and not change pitch except while speeding up.
is the lock-up anything special?
Previous poster.
SIG! thanks. i lol'd very hard
Originally Posted by chance_p
i have come to the conclusion that snow kills braincells
Originally Posted by Indy
If you only have the 1 clutch however, I'd suggest keeping it if you expect to move by anything other than 1. gravity or 2. transcontinental drift. Both are time tested to work, but you might not get exactly where you want to go.
Originally Posted by cheapfix View Post
Scanner? You don't even have doors... :p
cheepjeep96 is offline
post #18 of 20 Old 10-18-2008, 06:36 AM
yellow_xj
Ok im as confused as ever now. The past two days ive been searching for an answer. Here is the problem; With the cruise contol set at 60-65 driving on the highway flat ground the rpms will jump all of a suddon from 2250 to 3000 (approximation) then the cruise stops working and the rpms keep surging back and forth and i cant set the cruise again. I thought i found a solution (havent tried yet still researching) either the NSS or trans solenoid but now the Torque Converter card gets delt. BTW 01 xj 3" lift tc drop 255/75/15 tires if i missed anything its on my profile. Any suggestions?
01,4.0 W/Upgraded Injectors & Bored Throttle Body,AW4,NP231,D30 W/RC CA Drop,C8.25 W/Aussie Locker & Junkyard Disc Conversion,6" lift on 33X12.5X15.
Yellow Jeep Club member # 16
Jeeps dont die they get rebuilt bigger and stronger, like the 6 million dollar man!
yellow_xj is offline
post #19 of 20 Old 10-18-2008, 07:08 AM
Rollin
Id say the cruise problems and the rpm change are two different problems. The rpm change is the transmission downshifting to keep up the speed you set on the cruise control
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #20 of 20 Old 10-18-2008, 08:06 AM
yellow_xj
I would agree if i was on hilly terrain but im running completely flat road no elevation changes at all so the trans should have no reason to downshift to keep up. thank you for the responce and advice.
torque converter jjg214 XJ Cherokee Technical Forum 2 10-25-2009 10:19 AM
Torque Converter bomba6213 XJ Cherokee Technical Forum 4 07-04-2008 08:18 AM
torque converter seal leaking=new converter?? iwishihad1 XJ Cherokee Technical Forum 3 01-23-2008 06:38 PM
torque converter? xj 98/yj 94 XJ Cherokee Technical Forum 11 11-13-2006 08:50 PM
torque converter ? Trippe XJ Cherokee Technical Forum 3 02-16-2005 03:22 PM
