How to bypass window lock switch on my 98 cherorokee classic?
#1 | |
How do I bypass window lock switch on my 98 cherorokee classic? It started acting weird and I dont really need a window lock switch.
#2 |
Search there are some good write ups on how to do it.
I'm forever grateful to Speedycat and RnEmOvr for their generosity |
#3 |
I did and I found the one that repairs the switch but what I'm asking for is to tap the wire so its permanently engaged.
Hi dave.. |
#4 |
Hello I didnt realize you were new. Welcome
![]() Well I think this is what you are looking for. He is jumping a wire. You need to go to your profile and fill in your jeep specs. Makes it easier to answer questions. Linky
#5 |
you can do that bypass with out the splices if you know how to solder. just make sure you wrap them good with electrical tape.
jp
ROLL TIDE |
#6 |
Thanks a lot. This is great!!!! I will try this tommorow.
#7 |
Did anybody ever open the switch box? I tried, remove the 6 screws, dried but could not open it. Anyone?
#8 | |
Once you have the switch printed circuit board free from it's housing, you will find that all switches are soldered to the board, so they have to be repaired in place on the board. The lockout switch is a snap fit assembly. CAREFULLY prying the snap fit apart will release the top part of the switch, along with the spring and plunger. The switch body, with the contacts that are soldered to the board, remains attached to the printed circuit board. Unless you are familiar with small intricate assemblies, I do NOT recommend you take the switch apart as it's tricky to reassemble. If, on the other hand, you are good at this sort of thing, the switch can be rebuilt/rejuvenated, restoring the lockout function.
AZ-Jeff 1992 XJ 2" lift -- RIP 2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links. |
#9 |
It worked!!! thanks everybody...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
