Quantcast How to: Budget SYE - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How to: Budget SYE
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 08-22-2005, 10:37 AM   #1
Rock Kustoms
How to: Budget SYE
if someone could sticky this, cuz its coming up alot....
you need 3 parts to do this, and its only budget, if your driving a 96 or newer XJ
RE Hack and tap - $90
Splicer - 211229X - $40 or $50
Front DS from an auto XJ - $20 to $60 at a junk yard
thats it, heres a link w/ some pics
http://www.jeepsunlimited.com/forums/showthread.php?s=&threadid=630174
Rock Kustoms is offline   Reply With Quote
Old 08-22-2005, 11:36 AM   #2
SimpleXJ
Been thinking about this for a while... how did he adapt it to the rear axle? Another specialty ujoint?
Good info, thanks.
SimpleXJ
[COLOR=darkred]'88 MJ[/COLOR] - 197K, front bumper, 4" lift front, ford 8.8 & SOA rear
[COLOR=darkred]'96 XJ[/COLOR] - 240K, 5.5" lift, 33's, F&R bumpers, removable rear spare carrier, LED tail-lights, etc.
[COLOR=darkred]'89 XJ[/COLOR] - 200K on body, 20k on new jasper, 3" lift, 31's, F&R bumpers, led taillights
SimpleXJ is offline   Reply With Quote
Old 08-22-2005, 12:23 PM   #3
2qk4u
If i have a 98 xj with a dana 35, can i still do this?
2qk4u is offline   Reply With Quote
Old 08-22-2005, 12:34 PM   #4
Islandroaddie96
I think you can, but because the D35 pinion is a little shorter than the 8.25, you may need to get the DS lengthend a bit. Also depends on how much lift you have.
Good Luck,
Peter
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline   Reply With Quote
Old 08-22-2005, 12:52 PM   #5
XJ99
K I S W
XJ99's Avatar
I wonder how the front shaft will hold up. It's 2" wide, while the rear shaft is 2.5" wide.. I'd like nothing more then to get rid of the t-case drop! Nice find...
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline   Reply With Quote
Old 08-22-2005, 04:53 PM   #6
XJ99
K I S W
XJ99's Avatar
Another quick question.. What would be the minimum amount of lift needed for the font drive shaft to work? Would 3"s even be enough?
Old 08-22-2005, 06:04 PM   #7
NORxjCAL
good info
Be polite, be professional, have a plan to kill everyone you meet.
"The American Indians found out what happens when you don't control immigration."
NORxjCAL is offline   Reply With Quote
Old 08-22-2005, 07:38 PM   #8
Rock Kustoms
it should work from stock, to about 6"
the angle only pulls it out a little.....
Old 08-22-2005, 07:47 PM   #9
dcuballa
Would that driveshaft stand up to all the abuse that is put on it?? I
[url]www.greenlightracing.com[/url]
07-Driver Unknown
Sponsor Unknown Chevy Silverado
08-Driver Unknown
[B][U]HOLY CRAP THATS A LOT OF UNKNOWNS[/U][/B]
dcuballa is offline   Reply With Quote
Old 08-22-2005, 08:05 PM   #10
mravojed
Guyz, I don't get this at all with front driveshaft used as rear.. When I look under my jeep, front ds looks more like toothpick compared to beefy rear ds.
And also about the size, front seems to be at least twice as short as rear..
I can't make any pics at the moment, since it is night, but will post some tomorrow..
It is '87 Xj with manual trans, np231, d30 and d35..
  • '97 TJ - 2.5L, 4.5" BB+BL, 33x12.5 BFG MTs, 4.88 gears, front winch
  • '04 WJ - 2.7L CRD, 2.5" BB, 31x10.5 BFG ATs, family car
mravojed is offline   Reply With Quote
Old 08-22-2005, 08:09 PM   #11
n8zc
I think this question can fit in here...
I'm wonder about this one too... Is using a used front driveshaft with any SYE a good idea? I'm sure installing new U-joints is needed, but...
I wonder about "hack & taps" vs "big $ SYE's" and using a "front DS" vs a "custom DS". What can I say, I too would like to get by as cheap as possible without losing durability and reliability.
After looking at the pictures with the link posted earlier, it helps to understand the setup... but I still wonder about the "durability and reliability".
If I was building a "rock crawler", the choice would be clear. So I guess I'll keep on reading.
Thanks,
Cary
[FONT=Comic Sans MS]"Bob" '00 XJ 4.0L Stocker with Lots-O plans.
Rusty's Intake System. Hella 500's & Vision Plus Head Lamps.
[URL=http://]www.geocities.com/n8zc[/URL][/FONT]
n8zc is offline   Reply With Quote
Old 08-22-2005, 08:12 PM   #12
XJ99
K I S W
XJ99's Avatar
The front drive shaft should be around 26"s from yoke to yoke (at the bottom where the pinion nut is) Give or take depending on how much lift you have..
Old 08-22-2005, 08:17 PM   #13
XJ99
K I S W
XJ99's Avatar
Originally Posted by n8zc
needed, but...
I've never heard of a Hack and Tap failing.. I've heard of people running 35's with no problems.. If they are crap, I hope I find out before buying one..
Old 08-22-2005, 08:40 PM   #14
ktmracer419
1997 XJ Cherokee
what about us guys with older xj's? can we use one of the heavy duty sye's and make this work?
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote
Old 08-22-2005, 09:45 PM   #15
Silver TeeJay
My personal opinion is this - I would rather spend the 500.00 now versus 250.00 on this special edition SYE/DS and then if (IF) it fails then have to spend the 500.00.
To each their own - I do not go off-road a ton and if I do I am not gonna see how many rocks I can climb or how deep of mud I can troush through. I am going to go out and have fun!
Yup it is my DD, it is my Mall Crawler and it is my off-roader!
[B][COLOR="Silver"]2005 Jeep TJ "RME" - Bright Silver Metalllic - 4.0 Auto
2" BDS Coil Spacers / BDS Steering Stabilizer / BDS 5500 CAV Shocks / JKS 1.25" BL / JKS 1" BMML / Dana 44 / 3.73 Gears / Custom Rock Sliders / 32x11.50 BFG KO's / 15x8 AR Diamond Backs
[B][I][U][/COLOR][/B]
[COLOR="Silver"][SIZE="2"][COLOR="Silver"]Proud member of the KC Jeep Club![/COLOR][/U][/I][/B][/SIZE][/COLOR]
Silver TeeJay is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
