how bad is the rust damage? - JeepForum.com
post #1 of 17 Old 09-04-2012, 01:57 PM Thread Starter
Xanatos
1991 XJ Cherokee
Hey everyone, I've got a few rust spots under my floor pans and was what it is going to take to fix them. The main spots are under the drivers floor panel and next to the front of the rear leaf mounts. It appears the rust is not structural and should be able to cut the floor pans out and replace them with one of these http://c2cfabrication.com/store/adva...okee+floor+pan
Does the rust next to the leaf mounts look structural? or does it look just part of the floor panel? I really hope It's not something structural and I will just be able to cut it out and bolt new panels in. Let me know what you guys think.
This is the drivers side just before the rear wheel well.
This is the drivers side front leaf mount. It appears only surface rust on the mount itself, but I do not know if what is next to the mount is just floor pan or structural.
This is is the right side leaf mount.
https://sphotos-b.xx.fbcdn.net/hphot...41768092_n.jpg
This is the passengers side. It also appears to be starting some rust.
https://sphotos-b.xx.fbcdn.net/hphot...76041456_n.jpg
Here is my driver floor pan. The hole in the top left corner of the picture is actually where my right foot sits at the gas pedal.
https://sphotos-b.xx.fbcdn.net/hphot...87796284_n.jpg
Live free. Stay wild.
Xanatos is offline
post #2 of 17 Old 09-04-2012, 04:48 PM
rugsucka
You should really get to that rust in the shackle pockets very soon. If you hit the wrong bump you can push right through the floor. It's time to buy some metal and get welding. You can not repair this type of rust to be structurally sound with rivets and roofing tar. Bolt in doesn't really happen for floor boards. You need to cut out and weld in place. There is such a product as panel adhesive, but you would need to cut out, prep very well and only try to adhere to perfectly sound metal.
There are full floor pan kits available as patch panels.
The rockers are also looking pretty punky. You can also buy new rockers - once again weld in. Another option for the rockers is a 2x6 box tube replacement for off road durability. Once again.... you guessed it - weld in.
rugsucka is offline
post #3 of 17 Old 09-04-2012, 06:12 PM Thread Starter
Xanatos
1991 XJ Cherokee
Is the metal next to the shackle very structural though? It doesn't seem like it would be with such a small bolt holding it in place. I really want to learn how to weld.. would come in handy.
Xanatos is offline
post #4 of 17 Old 09-04-2012, 06:59 PM
grainofsalt
Yes it is. If you go to a thicker piece to replace it, If done right, will help stiffen the body.
grainofsalt is offline
post #5 of 17 Old 09-04-2012, 07:38 PM Thread Starter
Xanatos
1991 XJ Cherokee
Would it be best to go at it from underneath? or pull the floor pan out and tear brace it from the top?
Xanatos is offline
post #6 of 17 Old 09-06-2012, 08:11 AM
grainofsalt
I would pull the carpet and go from the top, Unless you want a fire hazard...
post #7 of 17 Old 09-06-2012, 06:18 PM Thread Starter
Xanatos
1991 XJ Cherokee
Haha I'm hoping to pull the carpet out anyways. Will I have to replace part of the floor pan? Or is that a separate piece of metal that is attached to the leaf mount? When I look from the inside I do not see that bolt that is sticking upwards next to the leaf mount. I would think there is a piece of structural metal and then the floor pan is on top of that. So I would have to tear/cut out part of the floor pan to even get to the other piece.
Xanatos is offline
post #8 of 17 Old 09-06-2012, 08:19 PM
Back_In_Black
boatsides!!!
its fixable.
keep us posted.
Back_In_Black is offline
post #9 of 17 Old 09-08-2012, 06:35 AM
raypla
Get that carpet out asap. Hopefully it won't be as bad as mine was, yes thats my driveway behind the seat rail
99 XJ 4.0 D30 29sp 8.25, IRO TB & HD Tie Rod, Kellys WIP main 5 wires 1AWG
, Banks header, Stainless Magnaflow catback, cat, 2" OME lift, JC1B Leafs, OME sports, JKS discos, 30X9.5X15 BFG AT's, Fastman 62mmTB, Cibie E-codes with 55/60 Osram bulbs, Putco harness=JUNK!!, Alpine 7563 Deck, PWX 10" Cubby, JBL GTI 180.2 400wX1 rms, 6.5 Infinity Perfects , front PWX 6.5, Infinity ref amp 111wX4 rms, Optima Yellow, 100 sqft of
raypla is offline
post #10 of 17 Old 09-08-2012, 09:11 AM Thread Starter
Xanatos
1991 XJ Cherokee
Thank fully its not that bad. I pulled part of the carpet up to look under there. It's only on the bottom in the pictures and next to the leaf mount. It hasn't come through the floor except where the gas peddle is. I'm just having a hard time finding someone who knows how to do this. I would rather not take it to a mechanic, but find someone who I can work with because I would love to help. And most mechanics don't want to work on this anyways.
Xanatos is offline
post #11 of 17 Old 09-08-2012, 06:15 PM
rugsucka
You need to order a floor pan kit for the affected areas, or 16ga metal and a BFH to shape it.
This is an easy repair with a MIG welder. You do not want to pay a mechanic shop rate to do what a high school shop class apprentice welder could do.
Find a welding shop or autobody shop and start asking for leads. There is always somebody willing to make some cash or beer on the side.
rugsucka is offline
post #12 of 17 Old 09-08-2012, 09:57 PM Thread Starter
Xanatos
1991 XJ Cherokee
Ok, so it is probably just the floorpan that adds to the structure of the vehicle and not a separate metal structural piece. I was also thinking if I had the tools, go to a junkyard with the owners permission and tear the junk Jeep up so I know what exactly I need to cut before I ruin mine.
I was actually thinking about stopping by the community college and seeing if they would take this on as a project, wouldn't cost but the parts and tips if they can do it. Especially considering most mechanics charge $70+ an hour
I don't think I'll be able to get beer for anyone though... still have to wait another year for that.
Xanatos is offline
post #13 of 17 Old 09-08-2012, 11:00 PM
rugsucka
Use c channel stock or L bracket metal to recreate any rotten seat brackets.
rugsucka is offline
post #14 of 17 Old 09-13-2012, 05:58 PM Thread Starter
Xanatos
1991 XJ Cherokee
Alright, I got someone that will look at it on tuesday! hopefully they will be willing to help me out. Turns out it was a little worse than I expected. It is rusted next to all four spring leaf perches. I will get a few pictures up later. I might just replace the whole rear floor pan and the drivers. Then patch up some of the other rusted spots with pieces of the old rear floor pan. The weird thing is that the majority of the rusting in the back is underneath the factory caulk. Very little rust is anywhere else, but pull up some of the caulk and it's rusted through in some places.
The biggest question is when I'm pulling up the floor pan, is it just spot-welded? I have yet to find video/pictures of people tearing the floor pan up. The videos are usually a before and after. Any thoughts on how to make pulling the floor pan up easier? I was thinking a puddy knife or chisel and a hammer.
Xanatos is offline
post #15 of 17 Old 09-13-2012, 06:17 PM Thread Starter
Xanatos
1991 XJ Cherokee
I went ahead and scraped some of the caulk away, and turns out it was rusted straight through. I guess the caulk must have been holding some moisture or something. Got to get that fixed soon.
Here is my drivers floor pan. As I thought it would be.
The other part I didn't get a picture of is right above the front leaf spring mounts, pulled some caulk away... and it's almost rusted through. I think I'm going to try to pull most of the caulk on the floors just to try and eliminate the problem.
Xanatos is offline
floor , floor pans , panel , replace , rust
Rust - POR15 vs. Rust Bullet vs. Eastwood Rust Encapsulator Jeep Cherokee XJ/MJ Cherokee Non-Technical Forum 15 02-10-2012 02:50 PM
Frame Rust and Engine Rust AequitasVeritas XJ Cherokee Technical Forum 12 09-24-2010 02:37 PM
35's and 4.56..damage possible? xtremexj59 XJ Cherokee Technical Forum 10 09-08-2009 12:33 AM
oil pan damage kanky1972 XJ Cherokee Technical Forum 4 04-17-2007 08:40 PM
damage DonEighties XJ Cherokee Technical Forum 1 10-06-2004 04:41 PM
