How to Add Extended Bumpstops - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How to Add Extended Bumpstops
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-12-2009, 06:33 PM   #1
xjbuilder00
1992 XJ Cherokee
I bought daystar extended front bumpstops but I have no idea how to install them. I've read somewhere that the housing breaks loos and installs via a stud but i can't break it loose?
Ok, So Whats The Speed Of Dark?
92' Cherokee Laredo - 3.5" OME lift, Rusty's Shocks, JKS quick Discos, Rusty's Adj Trac Bar
xjbuilder00 is offline   Reply With Quote
Unread 04-13-2009, 10:06 AM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
They pop out if you hit them with a hammer. Lube the new ones with some soapy water and press them into the pocket.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
