Hot under the hood and collar - JeepForum.com
post #1 of 2 Old 07-23-2012, 09:54 PM Thread Starter
michelt66
1995 FSJ Cherokee
Hi all. I am in need of some serious help with my Jeep Cherokee Sport.
She is a 1995 Sport 4x4 4.0 litre. I have poured over $4,000 into the engine and components over the last 16 months. I purchased a rebuilt engine and many other new parts and still can't get it to run properly. All cooling components to include radiator, hoses, thermostat, & fan clutch have been replaced yet she keeps overheating. It is mostly when I drive around town.
Below is a list of new components.
TPS, MAP, IAC, CPS, Water Pump, thermostat, Distributer, all hoses and belts, Fan clutch, plugs & wires, oxygen sensor, oil sending unit, heat sensors, power steering pump, fuel injectors, fuel filter, radiator, and I am sure there is more.
The engine has just under 6,000 miles since I purchased it from a local engine reman co. in Glendale, AZ.
I can only think of two things that would cause this problem in light of all of the new components on this vehicle. 1. the static timing between the crank and cam are one degree/tooth off, or 2. the head is not the proper one for this engine.
My reasoning for the latter is due to the fact that the original head had 2spots for temperature sensors. One for the guage in the front of the head, and one for the computer at the back of the head. When I spoke to the reman co, they said this was the correct head, and to put the heat sensor for the ECU in the block.
Any help would be greatly appreciated as I am at my witts end and ready to sell the thing and start new.
michelt66 is offline
post #2 of 2 Old 07-23-2012, 11:55 PM
ltrail
1984 XJ Cherokee
Couple silly questions. Do you have a fan shroud? Did you bleed the system properly? And does the e-fan come on when ac is on?
I'm about to run into the 1 sensor and two plugs also. Purchased a newer 4.0 and when you posted I thought I'd look at the two heads. What do you know they are different!
Thinking about how to adapt since I don't wanna pull the head.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
overheat , overheating , overheats , temperature spike
new crush collar when chnging pinion seal??? kenC XJ Cherokee Technical Forum 4 01-03-2010 02:01 AM
Steering Collomn Collar batchje MJ Comanche Technical Forum 1 09-24-2009 10:25 AM
Hood release cable broken...any ideas to open hood? jeeps4life XJ Cherokee Technical Forum 6 05-16-2007 01:16 PM
Blue collar or white collar lift jmundale XJ Cherokee Technical Forum 13 01-16-2007 07:34 PM
RE driveshaft - grease collar coming off?? EricsXJ XJ Cherokee Technical Forum 10 08-22-2003 11:55 PM
