#1 | |
Hot Floors
I removed the carpet in my '91 to fix som small rust spots in the floor and the carpet was so gross that i decided to leave it out and bedline the floor. I have been driving it for a little while with nothing on the floor and have noticed that the floors get very hot. Is there any thing i can put down before the bed liner to help insulate the floors? Or possibly some type of heat sheilding to put on the exhaust?
1997 Comanche - Started as a 1988 MJ 2wd 5 spd Now it has the front clip, motor, trans, axles and interior from a 1997 Cherokee. Long Arms and Locked on 32s. 1999 Cherokee DD |
#2 |
My floor gets pretty hot as well. I have thought about trying to fasten some heat insulation on the underbody, but I think that you would need quite a bit. The heat is coming off the exaust, engine, and the tranny. Seemed like more work than it was worth to me, but it is an idea.
Plus, it's like having heated floors in the winter!
1979 CJ-5 304 V8, 32x11.5 Kumho Mud Terrains, Edelbrock Intake, Carb, Cam 1998 Cherokee, 3.5" Lift, RE HnT SYE, needs installed, 31x10.5 Firestone Destination MT's, Herc'ed Interior. http://www.cardomain.com/id/bills79jeep |
#3 |
You might want to check the cat. When it starts to go bad, the heat increase is very noticeable.
'97 Cherokee Sport, 4.0 I6 4x2 Stock |
#4 |
the exhaust going into the cat is cooler than the exhaust coming out of the cat, so the cat heats things up significantly anyway.
my floors get hot due to carpetless and i love how i can just hose it down to clean it, but it gets too friggin hot. i was thinking small sections of carpet attatched by velcro or something.
97 xj 44 front, detroit, alloyed 60 rear, detroit, 35 spline alloyed 35" beadlocked km2's 3" midarmed more bells and whistles than you can shake a stick at |
#5 |
i had my muffler heat my floors up so much it melted a water bottle i had back there. and then there was a steam coming from under my seat and i was like what the . So I bought a flowmaster heat sheild from summit racing its a noticeable difference between with and without it. it costed me like 30 or 40 bucks and it deffinetly helped out.
"Your not Jeepin until you get stuck" "Im not jeepin unless i break something" |
#6 |
Yep, Summit would be a good place to start. Here's ten pages of different heat insulation.
http://store.summitracing.com/egnsearch.asp?N=700+4294923429+115+4294923290&NeXI D=5
2004 Wrangler X 4.0 2000 Cherokee Sport 4.0 1992 Dakota Sport 5.9 1971 Pontiac Firebird |
#7 |
HAHA
My fricken floors get hot with carpet
-Andrew Another Chero in progress |
#8 | |
My floors get hot, with just the herculiner, but its not really intolerable. I just turn the AC on if its too hot. |
#9 |
I think dynamat makes a heat insulating product that you could put down and then herculine it in.
Cut member club member #1 Arizona Jeep Club Member #8 Jeeps don't have IFS. |
#10 |
how about a heat shield? Take some sheet metal and place it between cat and floor to absorb more heat?
[U]1994 Jeep Cherokee[/U] SYE,6" RE with tnt y-link long arms, 33x12.5 BFG Mud Terrains, Nates 4x4 custom winch bumper [QUOTE=ktmracer419]either way thats ridiculously peepee enlargingly tall.[/QUOTE] |
#11 |
invent paint that you put underneath that will not get hot (is there anything like that)
Wojtek "who needs paved roads when u have a jeep" 87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac colorado jeep club member # 74 |
#12 |
So a heat shield above the cat and muffler looks like the best option. Also would the rubberized undercoating theat you spray on help with the heat? spraying it underneath before instattling th heat shield?
#13 |
i bet that stuff willl burn off in no time like a couple months. would some high heat paint help oin a heat shiel? maybe the paint will tae some heat insteadall to the shield?
#14 |
hot floors
if you are worried about the heat YOU feel as the driver, it's not from the cat or the muffler it's just as bills79jeep said it's from the engine, tranny and the section of exhaust from the manifold until it crosses over to the passenger side. I just drove mine 1600+ miles with over five hundred of those miles being on the beaches of n.c. with each day having a heat index of over 100 degrees. Mine is also herculined inside without a carpet and it didn't really bother me that much, it's only really hot near the trans tunnel while your driving. Get a small piece of dynomat glue it to a chunk of carpet and velcro it to the floor like ktmracer419 suggested. That will lesser yur heat problems and still allow you to remove the section of carpet for easy cleaning if you need...just my two cents
#15 |
yeah, my friend just bought a 94 cherokee yesterday and we noticed that the floor got really hot.... i'm gonna try a heat shield and see what that does
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
