Hose/line identification- Help! - JeepForum.com
post #1 of 6 Old 07-11-2013, 03:43 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I have a metal line that sits on the firewall behind the intake that has a inch of rubber hose coming off of it, the rest is gone.
The line looks like it runs back to the fuel tank. What is it for? And where did the rubber hose go?
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #2 of 6 Old 07-11-2013, 03:59 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I have the same exact problem this guy has, except I have an automatic. http://www.cherokeeforum.com/f2/most...d-help-109949/ What gives???
post #3 of 6 Old 07-11-2013, 04:03 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Also, my fuel evaporator canister only has two hoses running to it. The third spot for a hose is capped off, and looks like it came that way. So I'm not sure if that portion of the hose has always been missing or what.
post #4 of 6 Old 07-11-2013, 04:17 PM
Paradise XJ
1988 MJ Comanche
It's the line to the canister. The 3rd line is blank...none of my Jeeps have had a 3rd line.
There are two vents on top of the fuel tank, they each have a rubber vac hose that then comes together in a T, then the one single hose goes to a metal vac line. It is metal from there to close to the charcoal canister, then it goes back to rubber and Into the canister. The bigger of the two lines from the canister is the source vacuum from the intake/manifold. The "system" sucks fuel tank fumes through the charcoal canister and then in to the intake/manifold to be burned off.
It's an emissions thing. In CA they test the fuel tank to assure that the vents on the tank are connected to something. The valves on the tank are also known as "roll-over" valves, so if your Jeep is upside down it won't leak fuel. Is it necessary? In CA, yes...in my county anyway...and I live in the sticks.
If your area doesn't test for emissions or has looser regulations it probably isn't necessary and probably doesn't make it run any different...EXCEPT for there being a loose vacuum hose flopping around.
Than there's the whole thing about fuel leaking if you're upside down
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #5 of 6 Old 07-11-2013, 04:46 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Hahaha... Thanks for the quick and concise reply. I'm having a lot of moments like this, as I'm putting it all back together after a rebuild.
I suppose I'll have to hunt down the fuel smell in the cabin still..
post #6 of 6 Old 07-11-2013, 05:44 PM
Paradise XJ
1988 MJ Comanche
The fuel smell will likely take care of itself if you properly route the vent lines and make sure your rollovers are attached. The lines are meant to suck the fumes away. If the lines are broken/cut/not attached those fumes will come right in to the cabin. The only other reason you'd have fumes in the cabin would be a fuel leak under the hood...injector/fuel line etc. and should be fixed ASAP to avoid burning down all your hard work.
