Quantcast Hood release cable broken...any ideas to open hood? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Hood release cable broken...any ideas to open hood?
Old 05-15-2007, 06:51 PM   #1
jeeps4life
We have a 94 cherokee. The hood release handle is broken and the hood is in a closed position. Would anyone know if there is a way to release the hood? Possibly by removing the front grill? I would appreciate any help. Thanks.
Stock 2004 Red Wrangler Rubicon
Locker Mod - 4Hi and Independent Front and Rear
jeeps4life is offline   Reply With Quote
Old 05-15-2007, 06:55 PM   #2
severous01
pull the kick pannel and find the metal piece that connects to the plastic lever
place vise grips here and leave it there...now you can pull on the vise grips to pull lever.
severous01 is offline   Reply With Quote
Old 05-15-2007, 06:57 PM   #3
boredcherokee4l
1992 XJ Cherokee
x2
92 XJ Sport-AW4-NP231
Dana 30/Dana 35 w/LSD/3.55
3" Rustys Lift
32x11.50 BFG Mud Terrains
boredcherokee4l is offline   Reply With Quote
Old 05-15-2007, 07:00 PM   #4
jeeps4life
I appreciate the quick response, but I think the cable is detached all the way up at the spring loaded release up under the hood.....Thanks
Old 05-16-2007, 09:45 AM   #5
Mud Machine
Jeep Addict
Mud Machine's Avatar
This might help.
http://www.jeepforum.com/forum/f11/hood-stuck-down-cable-broke-need-help-384412/
GR8 Half Top Conversion Thread
Does your gas tank overflow at the pump?
SUBMIT FORMAL COMPLAINT HERE!
2005 Rubicon LJ Unlimited - 4 1/2" BDS Suspension - 285/75/16 Toyo M/T's - 12,000# Winch - Ground Pounder Fab Rear Bumper - FabRieckAtions Custom Front Bumper - Overkill Engineering Tube Fenders - GR8 Half Top - Rock Hard Cage - Banks Monster Exhaust - 5.13 Gears - High Performance Flux Capacitor
1976 CJ-7 - 33" Super Swampers - BDS 4" Suspension - 6 Point Roll Cage
Mud Machine is offline   Reply With Quote
Old 05-16-2007, 11:49 AM   #6
cmjust0
Yep.. Gotta take the headlight bezels, the grill (I think), and the headlights out, then remove a couple of awkwardly placed bolts to free the stationary...loop-thingies...in the engine compartment that catch the hood..
Oddly enough, I came here today to look for a better solution to the overall problem -- which, for me, still exists.. After getting the hood up and replacing the hood release cable with a brand new one three months ago, it snapped again Sunday. Luckily, the hood had already popped, so I just positioned the latches on the hood so they wouldn't grab the loops and wired it down..
I bet I hadn't opened the hood a half dozen times since I did the R&R, and yes, all the moving parts had been PB-blasted, worked back and forth until they moved freely, and then greased..
Apparently, though, what they say is true: You just can't polish a turd...
cmjust0 is offline   Reply With Quote
Old 05-16-2007, 01:16 PM   #7
spedly
2011 JK Wrangler
the whole xj hood latch setup is a joke i'm about to ditch mine for a set of hood pins
spedly is offline   Reply With Quote
Glock Forum
