Hood Latch Problem!!! Hood won't open - JeepForum.com
post #1 of 3 Old 11-07-2009, 08:35 AM Thread Starter
cherokeeKID
Guys my hood release is just loose like it isn't connected to the cable and the hood won't pop. Is this a known issue and anyone have this happen before? Any ideas on how I can get the hood open or even where to start?
1999 Jeep Cherokee Sport 4x4
4.0L (243ci.) w/ Automatic Transmission
cherokeeKID is offline
post #2 of 3 Old 11-07-2009, 08:57 AM
hubs97xj
1997 XJ Cherokee
Look at the bottom of this page. Common problem. The answers are there, you will just have to click some links and read.
hubs97xj is offline
post #3 of 3 Old 11-07-2009, 10:37 AM Thread Starter
cherokeeKID
1. remove headlight trim, headlamp bulbs, and the "basket" into which the bulb seats
2. behind the headlamp basket is a bolt head facing forward, approx. 1/2 inch size head. This is one of TWO bolts that holds the hood latch striker to the radiator core support structure of the body. Remove this bolt.
3. near the bolt just removed is an oval hole in the core support structure. Working through this hole, remove a bolt that faces UPWARD (head faces down) on the bottom of the upper flange of the core support. This bolt is the second bolt that attaches the striker to the core support, and is the same size as the first one removed
4. repeat these steps for the other side, and then the hood should pop free with the strikers still engaged in their latches.
5. replace the broken cable, lube up the bellcrank where the cable attaches under the hood, and reinstall the strikers (and their shimming washers!!) onto the core support.
6. test hood for closure/latching. Adjust strikers as necessary.
7. reinstall headlight components
Jeep hood latch problem rocafella99 XJ Cherokee Technical Forum 7 12-27-2009 01:42 PM
hood latch broke, any way to open without prying? berlinetta XJ Cherokee Technical Forum 1 03-11-2007 05:50 PM
Stuck hood, got it open but now it won't latch closed. Sorta urgent. viator XJ Cherokee Technical Forum 6 12-04-2006 07:32 PM
hood latch problem - help please Jaroslaw99 XJ Cherokee Technical Forum 4 03-23-2004 01:22 PM
Hood latch problem? NIN_Jeep XJ Cherokee Technical Forum 2 08-02-2003 04:01 PM
