Homemade Roof Rack XJ - JeepForum.com
post #1 of 23 Old 01-01-2014, 07:31 PM Thread Starter
ajyeepin8
Hey Guys, I am new here I have always read threads here but finally had something to add so I made an account
I have a 99 2 door XJ that is an awesome rig
I had a roof rack on it that came off of a Land Rover... it made it fit but it never was 100% so after it being on there for 5 years it started rusting so i junked it and wanted to buy a new one...
There was only 1 rack that i really liked. the JCR rack I think is a REALLY good looking rack and strong. The problem is that it is 1000+ bucks for all the stuff i wanted on it... So I got out my welder and made me one!
I started with Conduit because it bends well and it actually strong once its bent and welded. i used angle iron for the middle for strength
had to see what it would start to look like.
So here i basically did cross member bars for strength
i knotched the pipes so they would weld better
After making both sides i mad corner pieces so i could add to those later
all 4 sides
Now i needed a light bar
Next i wanted sleek bars going from the back to the front at a slight angle overall i wanted my rack to be kind of streamlined but still rough looking
and on the jeep again... I HAD TO MAKE SURE IT WAS LOOKING GOOD SO IT WAS ON THE JEEP ALOT HAHA
Next i needed cross members for the sides to make them strong
Next i did a rear bar
I brought the back bar in a little because i am going to put my high lift jack on the back so i wanted to rest it there
So after i got to here i stopped for 3 weeks or so...It started snowing and got cold and I couldnt figure out how to mount the rack on the jeep....I should have thought of that at first haha so i played with a couple of ideas and came up with mounting it to the factory mount points and taking off the stock rails that are there.
You can see i made L brackets and later cut them to size...
So now after all that i welded the Light tabs on it and sanded it...Primed and painted it
Now i put on the lights. I like the Square lights more because the jeep is so boxy and has square headlights so no PIA lights for me ;/
So here it is on the roof and wired up for the headlights
The tire is on
So as of today that is where it is at! i plan on putting on a shovel and the high lift jack.
I really want to figure out a bike rack for the top as well down the road...
hope you enjoy the rack and if you have any questions let me know id behappy to help
total cost with lights $180 :-)
ajyeepin8 is offline
post #2 of 23 Old 01-01-2014, 07:54 PM
ck1
2014 JK Wrangler
nice work...looks real good!
14 JKU. 3.5 RE JKS arms track bar discos
91 XJ Ltd,RE 3.5 Sf JKS Arms, JKS Track Bar,TNT uni stiffs
ck1 is offline
post #3 of 23 Old 01-01-2014, 08:20 PM Thread Starter
ajyeepin8
Thank you!
post #4 of 23 Old 01-01-2014, 08:59 PM
dharmabum
dharmabum's Avatar
Nice looking rack, can you post up some better pics of the mounts to the roof?
dharmabum is offline
post #5 of 23 Old 01-01-2014, 09:54 PM Thread Starter
ajyeepin8
Its really cold outside so there is some frost lol
i took some metal and made an L bracket. i was going to weld it straight to the rack but because of the demensions i wouldnt be able to get to the srew that goes to the roof so i bolted it to the rack
post #6 of 23 Old 01-01-2014, 10:32 PM
dharmabum
dharmabum's Avatar
Thanks I've been thinking of doing a flat rail that picks up all the stock holes with supports welded in to the bottom of a full rack. Have you had any issues with the stock mounting holes?
post #7 of 23 Old 01-01-2014, 10:42 PM Thread Starter
ajyeepin8
No my stock mounts are in good shape so no issues, its very strong, i can grab my rack and shake it and the jeep moves not the rack so its solid.
post #8 of 23 Old 01-02-2014, 04:41 PM
Xride
Looks good. Being a sparky I'm not sure I would use EMT, although I am sure it is strong enough, I just know I would always go for the one extra ratchet with my straps and would bend it up pretty quick.
For mounting to the rain gutter jrc really has a great design that is pretty easy to make on your own.
Or spend the few bucks to buy from them.
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #9 of 23 Old 01-02-2014, 04:42 PM
Azzy
How you like performance in corners with that tire up top?
Had mine up there for ... 2 days before it had to come down.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #10 of 23 Old 01-02-2014, 04:46 PM
Xride
I've had 200 lbs on the top of my XJ before (which makes the factory roof rack touch the roof in case you are wondering) and didn't really notice it felt any less sure footed than before, although would never wheel with it up there.
Xride is offline
post #11 of 23 Old 01-02-2014, 06:27 PM Thread Starter
ajyeepin8
My friend bought those from JCR and they failed pretty badly. I made my own but they looked weird on the rack i thought... Im really impressed how strong the stock points are. I had the tire on there with straps at first and had it tight enough to almost dent the tire lol and they held up great. so far so good! lol
post #12 of 23 Old 01-02-2014, 06:29 PM Thread Starter
ajyeepin8
I havent noticed a big difference. my jeep doesnt get great MPG anyways... most dont and its not my daily driver anymore so it doesnt bother me. Eventually im going to get a swing bumper with a tire carrier on it...so for now its up there because my trunk has alot of stuff in it.
post #13 of 23 Old 01-02-2014, 06:30 PM
Xride
I don't understand how they could fail? It's such a simple design.
Xride is offline
post #14 of 23 Old 01-02-2014, 07:06 PM Thread Starter
ajyeepin8
They snapped while we were on the trail. well 1 off them did not all of them.
post #15 of 23 Old 01-02-2014, 09:43 PM
sAe23
1995 XJ Cherokee
I know the tire takes up most of the room, but I'd want more cross bars so other things I might place up there didn't fall in between the other bars...
Otherwise
sAe23 is offline
roofrack , xj
