Quantcast Homemade bumper / air tank - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Homemade bumper / air tank
Old 06-13-2008, 07:32 PM   #1
zatch83
1992 XJ Cherokee
I'm making a bumper out of 3x5x1/4" rectangular steel tube. The plan is to seal it off with the welds and use my A/C compressor to fill it up. Has anyone ever done this before? Any idea how I should do it?
... /_(_)_(_)_(_)_(_)_/
...|[ŻŻŻŻŻŻŻŻŻŻŻŻŻ]|
...|[_____________]|
..//ŻŻŻŻŻŻŻŻŻŻŻŻŻ//
.//_____Jeep____//
|[O]||||||||||[O]|
zatch83 is offline   Reply With Quote
Old 06-13-2008, 07:38 PM   #2
bushytails
Lots of people have done that before. Try google.
--Bushytails
bushytails is offline   Reply With Quote
Old 06-13-2008, 07:55 PM   #3
redneckengineer
1997 XJ Cherokee
This is a tried and true design the only thing that I would caution you on is having the ends tig welded or brazing over the the weld if you mig weld it. Once you stop the bead on a mig weld it is next to impossible to get it air tight. You will also want to pressure test the bumper after you weld it.
redneckengineer is offline   Reply With Quote
Old 06-13-2008, 11:05 PM   #4
FASTnSPEEDY
1991 XJ Cherokee
Yes, google is good one for all the info on that one, but like others have said, getting airtight weld on the end it a pain. Make sure in addition to the nipple you have a way to drain it out and maybe an air gauge. (nice but not necessary)
I just gave up and converted it into a fuel tank, I can store an extra 20 gallons in the front and rear bumpers! Just kidding.
[CENTER][B]'91 XJ [/B] 126,XXX miles (110,XXX when purchased), (was) in mint cond. stock, fully loaded. 4wd + np242 -Mods: Harbour Freight lights on the bumper. 30"s, 2" bb, exhaust, other small misc stuff.
'96 XLT MANual [COLOR=Navy][B]Ford[/B][/COLOR] Ranger 151,XXX miles (113,XXX when purchased), mostly stock except for Cooper A/T tires and a CB
'85 Toyota Pickup 156,000 miles 22R, on 33"s [/CENTER]
FASTnSPEEDY is offline   Reply With Quote
Old 06-13-2008, 11:43 PM   #5
eflores
1989 XJ Cherokee
any one ever heard of arc welding with a stick?
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline   Reply With Quote
Old 06-13-2008, 11:52 PM   #6
bushytails
you mean smaw/stick, standard arc welding?
--Bushytails
Old 06-14-2008, 12:17 AM   #7
gijazbo
I [lan on doing this with my new rockers...... plus this is my 50th post so now i can put up pics with no clicky...... woooohoooooo.!
It sucks to own a jeep in NE Ohio
MOPAR.... Made Of Paper clips And Rubber bands
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
My build thread:
http://www.jeepforum.com/forum/f11/96-sport-build-project-809129/index2.html
gijazbo is offline   Reply With Quote
Old 06-14-2008, 12:22 AM   #8
EricsXJ
The Post man
EricsXJ's Avatar
Stick welding is arc welding, as is Mig.
I've made my rocker into an air tank and it is working well. It is difficult to do but not impossible. This was also discussed recently in a thread I responded to in the ZJ section. I think you'll find it helpful. http://www.jeepforum.com/forum/f13/use-sliders-air-tanks-553071/
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 03-18-2009, 02:11 PM   #9
PolloLoco
need more lemon pledge
PolloLoco's Avatar
How much pressure does the A/C compressor make?
Dash Mounted Video Camera
PolloLoco is offline   Reply With Quote
Old 03-18-2009, 04:45 PM   #10
RussoGuitar
1989 XJ Cherokee
I've made my rocker into an air tank and it is working well. It is difficult to do but not impossible. This was also discussed recently in a thread I responded to in the ZJ section. I think you'll find it helpful. http://www.jeepforum.com/forum/showthread.php?t=553071
What makes you say its difficult? I felt it was pretty straight forward...?
RussoGuitar is offline   Reply With Quote
Old 03-20-2009, 01:17 AM   #11
EricsXJ
The Post man
EricsXJ's Avatar
Making pretty looking welds is not that difficult. Making good welds that are air-tight IS difficult for many people including me. At least it was harder than I first anticipated.
Eric
Glock Forum
Copyright İ Group Builder, Inc - All Rights Reserved
