Quantcast Home made roof rack in the works. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Home made roof rack in the works.
Old 08-30-2008, 11:57 PM   #1
flaymon1
1995 XJ Cherokee
I've started building my roof rack here are some pic...
flaymon1 is offline   Reply With Quote
Old 08-31-2008, 12:03 AM   #2
1dayiwill
tight. what are you gonna put in it. what is it made out of. how heavy is it.
1996 XJ 2wd 4.0 HO
1dayiwill is offline   Reply With Quote
Old 08-31-2008, 12:12 AM   #3
flaymon1
1995 XJ Cherokee
Its made of 3/4 sguare stock and 1/2 round stock I'd guess it ways about
20-30pounds...
Old 08-31-2008, 07:21 AM   #4
Muddeprived
Dude you have great fabrication skills.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Old 08-31-2008, 07:25 AM   #5
flaymon1
1995 XJ Cherokee
Thanks bro!
Old 08-31-2008, 07:55 AM   #6
Alexia
You have great fabrication skills. Make some bumpers next with built in recovery points!
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Build Project Thread
Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ
Alexia is offline   Reply With Quote
Old 08-31-2008, 07:59 AM   #7
flaymon1
1995 XJ Cherokee
just ignore the shackle lets not open a can of worms been there got the t-shirt this thread is for the rack....thank for the comments thow I'm considering that idea.....any ideas on how to attach it to a xj without a stock roof rack.....
Old 08-31-2008, 08:06 AM   #8
Alexia
Sorry!
You can bolt directly to the stock roof rack, but it is not rated for very much weight. Just the roof rack you fabricated would probably take up half the maximum weight alone. The other methods are to use clips that mount into the water run off channels or bolt directly to the door pillars. Bolting to the door pillars will provide the best support, but may look bad if not executed properly.
Old 08-31-2008, 10:50 AM   #9
flaymon1
1995 XJ Cherokee
Originally Posted by Alexia View Post
Sorry!
Is this kinda what you were talking about?
Old 08-31-2008, 11:23 AM   #10
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
That's the way I'd do it. the gutter mounts are alot stronger than mounting to a factory roof rack anyway.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 08-31-2008, 11:37 AM   #11
wil badger
Honestly I would lower it down some and mount it onto some bars instead. With the mounts being so high you are creating a possible buckle point on your bends. If you just plan on using the rack for light weight stuff then what you have should be fine. But if you plan on putting your spare up there or something I wouldn't trust those mounts. You could possible make some gussets to go from the bottom of the mounting plates to the bottom of the rack.
How do you plan on finishing those mounts? You plan on making the small curved plate that grabs the gutter move in an up and down plan to grasp the gutter right?
This is a pic from a Warrior rack I had.If you see there is one bolt that moves the clasp up and down.Then there are two other bolts that are in slots. When you get it clamped down on the rail you tighten the smaller bolts to keep it in place.
One Built XJ
wil badger is offline   Reply With Quote
Old 08-31-2008, 01:48 PM   #12
flaymon1
1995 XJ Cherokee
well that's as fare as I'm getting today maybe I'll try to put the mounts on it tomorrow.
The rack is 4" tall and 4'x5' and weights 40 pounds exactly
Old 08-31-2008, 02:59 PM   #13
broncofire75
Dude get some pics of that totally awesome Spaer cover. That things sick!!
Looking good man. Now lift it, wheel it, lift it more, and wheel it more, then repeat....ha
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote
Old 08-31-2008, 03:12 PM   #14
flaymon1
1995 XJ Cherokee
here it is....
Old 08-31-2008, 05:53 PM   #15
Alexia
Yes, that is what I meant.
Glock Forum
