Hole in Roof Fix?? - JeepForum.com
post #1 of 2 Old 03-30-2013, 08:10 PM Thread Starter
Nuckingfuts
1997 XJ Cherokee
Hole in Roof Fix??
Just picked up a 97' xj and it looks like the previous owner drilled a hole in the roof (I can only assume for wiring??). It's smack dab in the middle of the roof though which seems kinda odd to drill a hole.
In any case, I have no use for it and I want to plug it water tight and paint to hide. The hole is about 3/4" dia and there appears to be some weathered silicone in there which I don't trust. They've also attempted to put some kind of cheap plastic cap over it (which I took off in the picture).
Got any ideas on a permanent fix? Thanks!
Nuckingfuts is offline
post #2 of 2 Old 03-30-2013, 08:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Some sort of antenna was probably installed there. 2 washer, a nut, a bolt and some silicone should fix that.
CJ7-Tim is offline
