Quantcast Hingeless Two Way Hood Vent Install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Hingeless Two Way Hood Vent Install
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 02-09-2008, 09:26 PM   #1
mortalenema
Drivin' me nuts...
mortalenema's Avatar
I just spent the day installing the 2-way vents. As promised, here's the write-up.
First off, I ordered these cool 2-way hingeless vents from Austin Hardware.
Today, I made some backing plates to strengthen the hood.
Then, I masked off the area of the hood I wanted to install these vents in.
I got some cool stainless allen head bolts to hold the vents down. I thought they would look better in black, so I painted them.
It took me about two hours to make sure I had all the measurements and such correct before I began cutting. I used a jigsaw. I think it might have been the first Craftsman jigsaw ever to grace the pages of the Sears catalog. At one point in the cutting, It decided it wanted to run continuously without permission. The trigger got stuck. I had to start cuts with the blade already moving. It was the suck. Eventually it worked itself out.
It's scary cutting a perfectly good hood.
After that it was just a matter of marking and drilling some holes, and bolting them up.
Here are some after pics.
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
**********More designs here**********
mortalenema is offline   Reply With Quote
Old 02-09-2008, 09:26 PM   #2
mortalenema
Drivin' me nuts...
Here’s a shot from the drive home.
Cooling seemed improved. It never got up to 210º. I know it’s about -4º here right now, but usually I can hit 210º in any weather.
Overall I like the vents. They have a lack of style that is beautiful all by itself. Utilitarian and purposeful. They do what they look like they’d do. Vent hot air and close when needed to keep the crud out.
I’ll try to get some better pics when going outside is a bit more comfortable.
'99 Classic: "Emma"
Jeeps with Teeth #1
MN Jeeper #14
Old 02-09-2008, 09:31 PM   #3
89XJ74
1989 XJ Cherokee
how much were the vents... they look very good
89' white XJ,4.0L, Auto, 2/2.5 RE lift, stock axles, 31" sport kings on wagon wheels, lights on roof rack and bumper-Sold
2000 XJ, 4.0 L, AW4, Dana 30/Chrysler 8.25, 3" skyjacker lift kit with 31" MTZ's, Hella 500FF, upgraded headlight harness and some extras.
89XJ74 is offline   Reply With Quote
Old 02-09-2008, 09:32 PM   #4
mortalenema
Drivin' me nuts...
30bux a piece.
'99 Classic: "Emma"
Jeeps with Teeth #1
MN Jeeper #14
Old 02-09-2008, 10:01 PM   #5
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Air pressure keeps them open?
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 02-09-2008, 10:05 PM   #6
mortalenema
Drivin' me nuts...
no, there are triangular brackets with detents that lock it in position.
you can see them on this picture.
'99 Classic: "Emma"
Jeeps with Teeth #1
MN Jeeper #14
Old 02-09-2008, 10:12 PM   #7
Guswut
Why did you install them front-rear as opposed to side-side? I would think that having them pointing the venting part towards the windshield would make the most sense to help melt any ice on the windshield, as well as venting hot air (pointing the venting end towards the direction of movement would be more of a forced air induction into the engine area, and thus it would also suck in loads of other stuff)?
They look really good, if not a bit tall. But then, who am I to call the pot black, right? Good job man!!
Guswut is offline   Reply With Quote
Old 02-09-2008, 10:20 PM   #8
mortalenema
Drivin' me nuts...
Well, as I see it, they are for venting hot air when I'm barely moving. Crawling along. They aren't a CAI or defrost, so I figured I'd mount them in a way that would look the most evil.
I did do the measurements, though. There is room to mount them at the rear of the hood in the vent/scoop position.
'99 Classic: "Emma"
Jeeps with Teeth #1
MN Jeeper #14
Old 02-10-2008, 06:44 AM   #9
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
I think I like them. They look kinda "Batmobiley" I still think it would be trick if you could raise/lower them via remote control.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote
Old 02-10-2008, 08:00 AM   #10
FlexdXJ
1997 XJ Cherokee
those are pretty cool looking. i like the fact that you can close them when its raining
97 XJ 4.0 AW4 NP231: BB, 31's CB, Surco Rack, , Autopals, Scangauge II, JCR tail light housings, basically Looks like JCR puked on it and some sweet hood pins! :D
FlexdXJ is offline   Reply With Quote
Old 02-10-2008, 08:30 AM   #11
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Pretty cool and deff different If they actuate easy enough, you could probably run a choke cable set to it and open/close them from the cab.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 02-10-2008, 09:35 AM   #12
mortalenema
Drivin' me nuts...
I thought remote operation through. The detents are pretty hard core. It takes some effort to position the vents. This does give me the option of setting them at different angles.
'99 Classic: "Emma"
Jeeps with Teeth #1
MN Jeeper #14
Old 02-10-2008, 02:11 PM   #13
trailblaze
looks neat...
i have a set of lebarron vents waiting to go on... it's cold enough outside now i saw no need to put them in untill spring...
Matt
trailblaze is offline   Reply With Quote
Old 02-10-2008, 02:36 PM   #14
ReconMill
Yes Man!
ReconMill's Avatar
2005
can they be pulled straight up so that all sides are open?
edit: are they steel or aluminum? I dont care to buy something thats just gonna rust. I have enough rust in the undercarriage as it is.
Kyle - I mod stuff®
SOLD!!! - 1999 XJ Build Thread
ReconMill is offline   Reply With Quote
Old 02-10-2008, 02:41 PM   #15
mall_crawler
Damn i really love those vents
[B][COLOR="Navy"][ ] lllllllllll [ ][/COLOR][/B]
The Trail Never Ends.....
mall_crawler is offline   Reply With Quote
Glock Forum
