Quantcast High Speed Shake (THE DEATH SHAKE) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > High Speed Shake (THE DEATH SHAKE)
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 03-10-2004, 02:53 PM   #1
skippythespy
When on the highway (mainly) if I hit certain bumps, the truck starts to shake violently. I replaced the steering stabalizer/damper, and it reduced the shaking, but it is still there. I put new coils in the front, and added a leaf in the rear to give a 2" lift all around. When it happens the only way to make it go away is to slow down to around 60km/h, then speed up again..Any ideas of what this could be?
skippythespy is offline   Reply With Quote
Old 03-10-2004, 02:57 PM   #2
rustinh1
it could be a broken belt in the tire, or bushings may be worn out. im not for sure though. mine was a broken belt in the tire on my TJ
-Rusty
2001 TJ Sahara - RE 4.5 springs, triangulated 4 links with custom arms, 60/HP44, 38.5s, cage, CB, CO2 complete with full lineup of air tools, the usual stuff...
rustinh1 is offline   Reply With Quote
Old 03-10-2004, 03:17 PM   #3
Jeeps4u
1997 XJ Cherokee
Skippy - I've had the same troubles. It could be a combination of things. The dampner will only absorb some of the shake, it won't cure it, I replaced my too in hopes it would help. Check out this post for more info:
http://www.jeepforum.com/forum/f11/front-end-shake-highway-speeds-72088/
97' XJ Sport-4.0L I6, Forest Green, full-faced brushguard, (6) spotbeam headlights, 3" Rough Country w/ 3.5" Pro Comp packs, newly added magnaflow cat and dyno muffler
Jeeps4u is offline   Reply With Quote
Old 03-10-2004, 07:36 PM   #4
jeep904x4
i had the same problem i thought it was the tires until i had them balanced and the figured ot it was my track bar i did not replace my track bar when i put on my 3 inch lift and it caused some problems
jeep904x4 is offline   Reply With Quote
Old 03-10-2004, 11:01 PM   #5
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Have the tires checked for balance. Then check the Trac-bar for looseness.
HAVE AN ALIGNMENT DONE! Any lift will change the geometery of the suspension, even if it's ever so slight, this could be what is causing it to happen.
I replaced, repaired, and verified my entire front end to get rid of my DW (Death Wobble) and it ended up being the alignment.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Glock Forum
