HIGH RPM backfire??? - JeepForum.com
post #1 of 11 Old 03-21-2009, 10:44 PM Thread Starter
AzBuckfever
1995 XJ Cherokee
So I've been reading these threads and trying to diagnose an issue with my '95 XJ. I have an AX-15 (5 spd) tranny and when driving, I'll go to up shift and the Jeep backfires. I'm trying to explain it the best I can So for instance, I'll shift at 3,000ish RPMs from 1st into 2nd and when it drops, it back fires/pops. I think that makes enough sense.
A few things I have thought about are:
#1; I have a bad or some bad injectors (of which I intend on replacing my plugs and wires in the next couple days and wondering if I should include some new injectors as well).
#2; I'm getting a misfire/hesitation and not burning all the fuel which is being sent through the exhaust and detonating in the CV or Muffler (weird, I know)
#3; bad plugs/wires which is leading to a miss somehow, or the Cam sensor is bad.
Also, I'll say that recently, the distributor & O2 sensor was replaced from an off-roading misadventure The entire distributor assembly was replaced (shaft, cap, etc.)
One last thing as well....The engine does idle a little rougher than my previous '96 that I owned. I'm thinking that instead of diagnostics/preventative maintenance and singal repairs, I should just replace all of it; unless I am heading in the wrong direction?
Thanks for your help.
AzBuckfever is offline
post #2 of 11 Old 03-22-2009, 07:19 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Any check engine light? Did you have these symptoms BEFORE you replaced the distributor?
I'd start by checking fuel pressure at the schrader valve on the fuel rail. Backfiring can be indicative of an improper fuel/air ratio. Gotta eliminate basic fuel issue as a cause and it only takes a gauge and 15 minutes of your time.
Pulling and inspecting a spark plug or two and closely examining them to see how they are burning may be a good idea.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 11 Old 03-22-2009, 07:45 AM
JoBo
Check for exhause leaks. Is your manifold loose or cracked?
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #4 of 11 Old 03-22-2009, 11:44 AM Thread Starter
AzBuckfever
1995 XJ Cherokee
This was a problem prior to the distributor replacement; but it may be a little worse now...not sure....As for exhaust, I thought about checking that as well because I think the collector has been smashed/clamped. Maybe if I have time before work, I'll crawl under and check it out. Thanks for the ideas. Even bigger perk is I have a fuel pressure gauge from when I had my '96 and had some stalling issues.
post #5 of 11 Old 03-22-2009, 11:47 AM
3shifty
It just seemed a little odd to me how high you go with your rpms when you shift, I shift around 2.5k or so, and if i went up to 3k my engine would be screaming. maybe my tachometer is off..
3shifty is offline
post #6 of 11 Old 03-22-2009, 12:13 PM
BrunoS
funny...i shift my 5spd at many rpm's depending on power need. i can drive in traffic just past idle or scream it to 5000 rpm if desired. it's an engine, not a woman.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #7 of 11 Old 03-22-2009, 12:17 PM
BrunoS
as for backfiring...weird...good possiblity ignition or fuel timing is off.
on the xj, distributor signal sets FUEL injection timing.
flywheel sensor set SPARK timing.
sounds really good that your fuel timing is off...the distributor is not supposed to be adjustable.
BrunoS is offline
post #8 of 11 Old 03-22-2009, 12:44 PM Thread Starter
AzBuckfever
1995 XJ Cherokee
Well, the only thing I saw with the exhaust is a pinch (narrower area) right above the O2 Sensor and about where the collector is....checked the fuel pressure...34PSI at idle 40-42 at rev and recovers to 34 from 30 when throttle is released...
The other question I was gonna ask is when some of you shift (what RPM) I've gotten mixed answers on this and from my experience driving stick, I normally shift when it feels right I'll be replacing the wires/plugs, possibly injectors afterwards, and who knows what else in the next week or so....
So, what RPM do you cruise at and what RPM do you shift at? I've been cruising around 2500 and shifting around 3000....Been thinking maybe it's a little high but as said, got this info from some others on different boards.
post #9 of 11 Old 03-22-2009, 11:04 PM
BrunoS
pinched exhaust is normal. factory made and installed. yes, it is.
higher velocity exhaust flow assists in "scavenging" (sucks exhaust out of cylinders) and helps mgp. it's a discovery every XJ owner makes as in "hey my exhaust is pinched".
your fuel pressure is low. should be near 49 psi. I suspect a plugged $12 fuel filter. up to 96 year, very easy to change.
as for shifting rpm, i do it all: low rpm shift in traffic, 1 to 3 to 5, or if going downhill from a stop/slightly rolling in traffic, start in 2nd gear, etc.
my shifts are all over the place. as for rpm/speed, i can tell you it's 2k rpm at around 73 mph on the gps in 5th gear with 31" tires and 3.07 gears.
2nd gear tops out at redline 5200 rpm near 60 mph. it's fun. pulls like a banshee from just off idle, fun REALLY starts at around 1800 rpm.
your backfire i suspect is lack of fuel volume/pressure due to plugged filter, which shows up as extra fuel when you shift and rpm drops, the injectors catch up to flow as the rpm drops when you let off the throttle and bam you have your backfire. try changing the possibly original fuel filter and a few bottles of techron to your next full tank of gas. the techron ain't cheap, but holy cow it cleans injectors/heads/intake/exhaust/valves/piston tops/rings like you would not believe.
BrunoS is offline
post #10 of 11 Old 03-23-2009, 11:29 AM Thread Starter
AzBuckfever
1995 XJ Cherokee
Not sure what any of you talk about when you say "Techron"...I bought a fuel filter and a couple cans of SeaFoam (O2 sensor safe). I saw some fuel injector cleaner and such but the closest thing to Seafoam was some Valvoline Synthetic cleaner. Another reason for the seafoam is that is the only thing they had a few cans in. Anyway, I'll dump a can in unless you don't think the 2 cans I bought will be too much?
post #11 of 11 Old 03-23-2009, 12:46 PM Thread Starter
AzBuckfever
1995 XJ Cherokee
So, I replaced the filter and still at 34PSI....That didn't help any Hmmmm, what to do, what to do....
UPDATE: WOW Bruno, your system must be FLAWLESS!!! So, replaced the filter and nothing. FInally, I found my Haynes manual and it says the pressure should be between 36 and 50 I think....If it's low up to 20PSI low, replace the regulator, if more than that, replace the pump. So I replaced the regulator and got 39 PSI...still not what I'd want but an improvement....I can't believe how much that little walnut size regulator costs though....$105.00 THAT'S INSANE!!!
Any other idears???
Intake backfire? svshaw82 XJ Cherokee Technical Forum 15 08-25-2011 05:00 PM
94 XJ sputtering and backfire Bones741 XJ Cherokee Technical Forum 10 12-16-2009 05:17 PM
89 XJ 4.0 backfire through airbox under load cherojee XJ Cherokee Technical Forum 12 12-14-2008 02:55 PM
Carb-like backfire through air box. 4.0H.O.XJ XJ Cherokee Technical Forum 4 06-18-2008 01:54 AM
backfire and hesitation m3810 XJ Cherokee Technical Forum 3 10-14-2001 07:07 PM
