High pitched whine when I let off the gas. - JeepForum.com
post #1 of 12 Old 12-13-2012, 06:22 PM Thread Starter
deitzberg
I have a 98 xj with a straight six. When ever I let up on the gas pedal I hear a high pitch whining. As soon as I hit the has even in the slightest it goes away. I did just have a new exhaust system put in so its actually a lot quieter so I dont know if it was there before as well. Any thoughts?
deitzberg is offline
post #2 of 12 Old 12-13-2012, 07:23 PM
CCKen
CCKen's Avatar
Is this with the Jeep in motion, or standing still? Is the whining definately coming from the engine?
CCKen is offline
post #3 of 12 Old 12-13-2012, 07:39 PM Thread Starter
deitzberg
Both. Its not the belt I just replaced it a few thousand miles ago and I just made sure it was tight. It seems like it is coming from the front.
post #4 of 12 Old 12-13-2012, 07:52 PM
CCKen
CCKen's Avatar
If you hear it while the Jeep is not in motion, try raising the hood and adjust the throttle by hand while listening for the whining. Sounds like a vacuum leak in a way, but could be the power steering pump, water pump, or anything in motion.
CCKen is offline
post #5 of 12 Old 12-13-2012, 09:21 PM
Winterwheeler
2009 JK Wrangler
A family 87 Cherokee Laredo also produces a high pitched whistling sound at idle once it's warmed up. Someone suggested it could be a leaking intake manifold gasket. I would like to know how to diagnose this issue and get info on how urgent it might be to deal with.
Nolo Secundi Carborundum Illegitimi
Winterwheeler is offline
post #6 of 12 Old 12-13-2012, 09:35 PM
wgirvine
1992 XJ Cherokee
Hate to say this but a high pitched whine when you are running down the road and let off, usually means ring and pinion gears are worn.
The road goes on forever, the party never ends....
wgirvine is offline
post #7 of 12 Old 12-16-2012, 03:57 PM Thread Starter
deitzberg
that is what I am leaning towards as well. I just had the exhaust manifold replaced. I read somewhere that the bolt in the back sometimes comes loose a hair and causes the sound. I just sucks that I had the work done in ohio and I cant take it back for them to deal with it since I am in PA next to jersey.
post #8 of 12 Old 12-16-2012, 05:10 PM Thread Starter
deitzberg
I just got done tightening all the bolts on the exhaust/ intake manifold. I let it warm up for 10 minutes and drove it for another 10 and I dont hear the noise. Hopefully that was the cure. I did find one bolt against the firewall on top that was a little loose. I will check back in at the end of the week for the final decision.
post #9 of 12 Old 12-17-2012, 12:48 PM
Name
@winterwheeler the easiest way to figure out if you have a vaccum leak is to start it, pop the hood, and spray the engine bay down with some carb cleaner or something similar. If it revs up you have a leak somewhere
Name is offline
post #10 of 12 Old 12-17-2012, 04:12 PM
OnTheFence
Can you take a photo of the exhaust/ intake manifold bolt that was loose?
I hear this is common. I'd like to check mine!
OnTheFence is offline
post #11 of 12 Old 12-17-2012, 04:25 PM Thread Starter
deitzberg
I will post one tomorrow afternoon.
post #12 of 12 Old 12-17-2012, 06:25 PM
mschi772
1997 XJ Cherokee
EDIT: deleted unnecessary reply
mschi772 is offline
4.0 liter , 98 jeep cherokee , whining noise , xj
