High pitch whistle noise coming from fuel pump - JeepForum.com
post #1 of 11 Old 01-05-2005, 05:44 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Question High pitch whistle noise coming from fuel pump
I just replaced the fuel pump and the filters in the tank. Now when I start the Jeep I can hear a high pitch whistle noise coming from the tank while it's running. A couple friends I've talked to seem to think it's normal, but I've never noticed it before. Let me know if anybody else hears this dog whistle coming from their tank. Thanks.....
BTW, the Jeep doesn't die out anymore on left hand turns when low on gas. I fixed the sumbiatch!
I'll do a write up later.......... I just hope the new fuel pump I bought is ok....
Late
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #2 of 11 Old 01-06-2005, 06:08 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
btt
Nobody on the board with a 97+ has this high pitch noise coming from the tank?
That must mean I bought a faulty fuel pump...
XJ99 is offline
post #3 of 11 Old 01-06-2005, 06:57 AM
Helicop
Helicop's Avatar
Yup,, every fuel pump I have ever known to whistle was just bad, the bearings in the motor or something are shot.
Man,,, bad luck you have :<
1992 Jeep Cherokee Laredo 4X4 4.7 Litre HO
---4.7L Stroked, Cammed, Bored .060---
--- 3" RUSTY'S/MISC BB LIFT---
---30X9.5 Firestone Destination Mud-Terrains---
---62mm Bored TB---
---High Flow Cat & Flowmaster 50 Delta---
---Pacesetter Armor Coat Header---
---Misc. Engine Mods---
---Overhead Light Bar---
___--==Helicop==--___
Under 21 Member #24
Helicop is offline
post #4 of 11 Old 01-06-2005, 07:05 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Crap, maybe I'll go drop the tank again and replace the new pump with the old one and just use the new filters...
I think the filters were the only problem from the get go anyway, but I had to by the whole kit (pump and all) to get the stupid filters...
thanks.........
XJ99 is offline
post #5 of 11 Old 01-06-2005, 09:02 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Update: I dropped the tank once again....
I believe the pump to be good. The problem I think I'm having is seating
the pump to correctly pick up the fuel. I took it out and tested it (with fuel)
and the whistle sound goes away. I also tested the old pump, with fuel it
doesn't whistle, without fuel it whistles as well.
Is there something I'm missing>>??
XJ99 is offline
post #6 of 11 Old 01-06-2005, 11:38 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Now, I tested the new fuel pump inside the tank. It made no whistle sound. I mounted the tank to the Jeep and hooked everything up. BAM fecking whistle comes back.
XJ99 is offline
post #7 of 11 Old 01-06-2005, 12:22 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
Take off,....nuke the site from orbit. THAT SUCKS!!!
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #8 of 11 Old 01-06-2005, 02:13 PM
Helicop
Helicop's Avatar
Dang man.. I can only hope that you were just dreaming about installing the old pump, testing it while outta the jeep, then you came back to reality and tested it and it whistles ..
---62mm Bored TB---
Under 21 Member #24
Helicop is offline
post #9 of 11 Old 01-06-2005, 02:22 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
^^^^^^^^ yeah, on the plus side it's running perfect and doesn't die anymore on left hand turns like it use to. Who knows maybe after a couple tank fulls it might go away.. I'm done dropping the tank, and getting high on gas fumes.. Time for a beer....
XJ99 is offline
post #10 of 11 Old 01-06-2005, 02:26 PM
cheesycook
cheesycook's Avatar
One word,.....DYNAMAT.
Hermiston, ORL
post #11 of 11 Old 01-06-2005, 02:39 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Yeah a while back there were tons of threads stating that the newer XJ's die on left hand turns when they had a 1/4 tank or less. Everybody said keep more then a 1/4 tank of gas in it and problem solved. The problem is in the filters. There are 2 in the tank, problem is Jeep doesn't sell the filters by themselves. I found a kit on Ebay that has them for $89.00 including a new Mopar pump. It's better then spending $350.00 at the dealer for a new unit. (filters, pump, sending unit, float)
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7944471866
I took plenty of pics and plan on doing a write up..... not today it's beer:30.....
XJ99 is offline
high pitch noise barrypwalters XJ Cherokee Technical Forum 10 01-04-2011 02:18 PM
High pitch noise coming from engine Dave72688 XJ Cherokee Technical Forum 3 02-22-2009 05:29 PM
Weird No fuel Pump Relay = No High Idle... RamboPants XJ Cherokee Technical Forum 19 04-19-2008 06:43 PM
High performance fuel pump alexrule123 XJ Cherokee Technical Forum 1 01-26-2008 12:49 PM
High Pitch Temporary Noise From Engine Compartment RodB XJ Cherokee Technical Forum 3 07-08-2007 03:22 PM
