Quantcast High pinion dana 30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > High pinion dana 30
Old 02-18-2008, 10:04 PM   #1
wannabexj
High pinion dana 30
Okay, I have a 2000 sport with the low pinion dana 30 that is starting to leak everywhere and would like to put in a high pinion 30. What years came with them and how difficult will this be? Thanks
wannabexj is offline   Reply With Quote
Old 02-18-2008, 10:25 PM   #2
Steamer98
84-99 I believe, all you would want to be aware of is the vacuum disco version of the early models.
98 XJ Limited
Stock XJ tire carrier for sale
http://www.jeepforum.com/forum/showthread.php?t=424930
Steamer98 is offline   Reply With Quote
Old 02-18-2008, 10:26 PM   #3
1990JEEPXJ
1990 XJ Cherokee
1984-1999 had them but i would say the newer the better. older ones had a vacuum disconnect front axle that would need to be addressed. would be a direct swap, not too difficult
Twin 242's
The 'build' thread
1990JEEPXJ is online now   Reply With Quote
Old 02-18-2008, 10:29 PM   #4
TwistedXJ
I just aqiured one with the Vac Disco and all you need to address that is a 33.00 plate that goes over the area after you remove all the equipment then you need on piece shafts.
1996 Jeep Cherokee SE 4.0L HO, 4x4
Dana 30 & 35; 3.55
4.5" RC Lift NON AAL
American Racing Baja 15x10
Daystar Stinger Front Bumper
Custome Rear Bumper
TwistedXJ is offline   Reply With Quote
Old 02-18-2008, 10:29 PM   #5
600dollarXJ
95+ had larger ujoints... I think. (it's in the sticky at the top of the forum)
88 Jeep Cherokee - 4.0 - AX15 - 231 - d30 disconnect with welded spiders - d35+aussie
1998 Suzuki TL-1000R
600dollarXJ is offline   Reply With Quote
Old 02-18-2008, 10:35 PM   #6
Steamer98
Good point!
98 XJ Limited
Old 02-18-2008, 10:37 PM   #7
1990JEEPXJ
1990 XJ Cherokee
but older ones with ABS also had the bigger u-joints. none that have the 242 have the vac disco. so a 1990 with a 242 t-case and ABS is the same as a 99, but newer is better.
Twin 242's
The 'build' thread
Old 02-19-2008, 08:51 AM   #8
lifted92xj
1992 XJ Cherokee
the vac disconnect ended in like 92
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline   Reply With Quote
Old 02-19-2008, 08:53 AM   #9
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
yup.
1234567
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/
5.9 ANDY is offline   Reply With Quote
Old 02-19-2008, 09:11 AM   #10
alwaysready
Ya i guess you can call it the weak link but first what are your mods?
Are you sure you need to change it?
what is the primary purpose of it?
how often are you gonna go wheeling?
If i ever broke mine then i might switch to a HP but my LP is just fine with the 3.55 31's
and ive heard alot of people say even with 4.5 and 33's they have no problems with the LP.
If you brake more than 1 LP 30 than i would say you should be going to a 44 anyways.
2000 XJ LIMITED DD
3.5" Rubicon Express lift OME shocks
31" Mtr's on Moabs
Warn Winch bumper
Smittybuilt Winch
Aj's Super Rock Rails
Black XJ on Moabs Club Member #1 :D
alwaysready is offline   Reply With Quote
Old 02-19-2008, 09:13 AM   #11
craminator66
I just picked up a '92 with 4.10 gears to replace my crappy lp d30. Definitely do not mess with getting a vac disconnect d30.
-Randy
00' XJ (lift, tires, HP dana 30 4.10's, Aussie Locker in front)
craminator66 is offline   Reply With Quote
Old 02-19-2008, 09:26 AM   #12
WMW0505
Not to hijack your thread, but I recently put new pads and rotors on my LP D30 and plan on switching to a HP D30 this summer...are there any years that I will be able to switch my pads and rotors from the LP to the HP?
2001 XJ 3.5" Rubicon Express Super Flex w/ 2" BB
AW-4
D30 w/ Aussie Locker
D44 open
33x12.50 Dunlop Mud Rovers
4.56:1 gears
WMW0505 is offline   Reply With Quote
Old 02-19-2008, 10:05 AM   #13
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Your answer is a sticky ->http://www.jeepforum.com/forum/showthread.php?t=360959
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 02-19-2008, 10:16 AM   #14
WMW0505
Originally Posted by CJ7-Tim View Post
Thanks dude, I should of looked there first .
AW-4
D44 open
4.56:1 gears
Glock Forum
