High Pinion D-44 upper and lower control arm bracket locations - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > High Pinion D-44 upper and lower control arm bracket locations
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off +
Unread 02-09-2010, 09:39 AM   #1
Cherokee_999
i have a 1996 xj with a 6.5" Rubicon Express long arm kit. I have just bought a hp d44 front diff and a ford 9 inch for the rear. i was just wondering if anyone could tell me the easiest way to locate the new brackets on the front d44 and were to locate them.
Cherokee_999 is offline   Reply With Quote
Unread 02-09-2010, 02:06 PM   #2
justanotherjpr
T&T Customs, Inc. Home Page has a truss that should take care of it for you. Welcome to the forum. You can also try INWAdventures.com - - - Offroad, Pyro, Outdoors for more local guys. I know a few on there have swapped HP44's into XJ's and can offer more help.
justanotherjpr is offline   Reply With Quote
Unread 02-09-2010, 02:16 PM   #3
foggybottombob
I used a high pinion dana 30 axle and took measurements from that. I used a bevel square to get angles with and then transferred those angles to a piece of paper so I could measure it with a protractor. It is a lot easier to get the brackets right if you buy pre welded UCA and LCA brackets with the angles already on them. The LCA brackets are canted 5 degrees from parallel to the axle tube. The UCA brackets are 12 degrees off parallel to the axle tube. The more pre fab in the brackets you buy the more expensive they are (as you would expect). I put a waggy d44 on the front of my XJ and getting the UCA and LCA brackets in the right place was by far the most difficult part for me.
foggybottombob is offline   Reply With Quote
Unread 02-09-2010, 03:44 PM   #4
Cherokee_999
yea the truss kit from tnt would have been easier but i already ordered all the brackets from rustys so now im stuck doin it this way any one from spokane that might be willing to help or do it for me?
Unread 02-09-2010, 07:06 PM   #5
justanotherjpr
Wayne at AllJeep would probably do it, but I don't know what he charges. He did the gears on my D30 and my 8.25. He's up in Mead. Welcome to AllJeep.com! We are here to help you get it right...The first time!
