high output alternator for my xj - JeepForum.com
post #1 of 7 Old 10-30-2009, 04:23 PM Thread Starter
xj_army
I need a high output alternator for my xj. Looked and looked, and found mean green alternators but they dont seem to offer one for my year xj. Any ideas???
'99 xj 4.0
xj_army is offline
post #2 of 7 Old 10-30-2009, 04:54 PM
Rollin
'99 xj 4.0
V8 ZJ alt is 146 amps which should be plenty for whatever you are running. Needs little modification. I think you need to shave a little bit off your bracket and it then bolts right in.
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #3 of 7 Old 10-30-2009, 05:18 PM Thread Starter
xj_army
is 146 enough to run a 12k winch at an idle? and alos what year zj and how difficult is it to grind off part of the bracket?
xj_army is offline
post #4 of 7 Old 10-30-2009, 05:30 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
The alternator on my big rig won't run a 12k winch at idle, or anywhere else for that matter. As an example, big rigs will normally run @140 amp alt. but have 4 batteries with 1000cca each. See the point I am making?
The winch uses battery power. The alternator just keeps the battery topped off.
A high quality battery and a regular alternator will do just fine, I have never replaced an alternator due to winching but always run a quality battery.
If you want a higher output alternator, then fine, but never expect it to run a winch.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #5 of 7 Old 10-30-2009, 05:35 PM Thread Starter
xj_army
Martin
IM running triple batteries with 1000 cca each. An alternator not designed for more then one battery will die very quickly i frun in a system with more then one battery. I was going to run the winch and lights off the 2 extra batteries through a isolator but I dont know if my stock alternator will be able to hold the volts up if I had to use my winch a close to max capacity. Im prolly worrying more then I need to just dont wana be stuck on the trail and have the alternator stop working cuz I over worked it. And a new one is like $200.
And Rollin, the v8 zj alternators only put out 90 amps so not sure where your getting your info from.
xj_army is offline
post #6 of 7 Old 10-30-2009, 05:44 PM
leftlanetruckin
XJ on 37's
Dont know what to tell ye there bud.
I have never had a single issue with 1 optima and a standard alternator.
If you want the extra weight and hassle of 3 batteries, your call.
One thing I do agree with you though, you are over thinking it.
And one thing......I have never ran into an alternator that "knows" if it charging one battery or four. So I haven't a clue where that "knowledge" comes from. Every time I have replaced an alternator on a big rig (where they come with anywhere from 1 to 4 batteries), I have never been asked how many batteries I have. Same alternator for each setup.
Martin
post #7 of 7 Old 10-30-2009, 05:50 PM Thread Starter
xj_army
Martin
Just something Ive come across searching. Dont remember where I saw it just wasnt sure if it was true or not. And I would think with the isolator it would make it even easier because of the extra batteries. The original is gona stay charged cuz its not getting any extra pull then normal so then the alternator shouldnt have to work hard at all to keep 2 others charged when they are huge batteries. I dont see where a winch could drain them enough and fast enough to hurt the alternator. But that was just stuff I read. I think I should be fine considering, how often will i even use my winch.
But thanks for the input guys
xj_army is offline
High Output Alternator or Dual Battery? JohnnyEpic XJ Cherokee Technical Forum 24 11-20-2009 10:08 AM
High output alternator? EnderUSAF XJ Cherokee Technical Forum 2 03-21-2008 02:55 PM
who has a high output alternator in their XJ and/or 1800+ watt system? BigOrangeXJ XJ Cherokee Technical Forum 5 06-07-2006 05:36 PM
Too high of output stock alternator.. Tjs88xj XJ Cherokee Technical Forum 5 10-27-2005 10:02 AM
High Output Alternator rewiring upgrade. wyrdvans XJ Cherokee Technical Forum 0 08-03-2004 12:18 PM
