High Output 4.0 - JeepForum.com
post #1 of 7 Old 11-13-2004, 07:49 PM Thread Starter
XYKJohn
High Output 4.0
I have just purchased a 2000 Jeep Cherokee Sport with a 4.0. It is a nice vehicle with a great package. I have a 96 Jeep Cherokee with a 4.0 “High Output”. There is a noticeable difference in the power of the 2 vehicles. What is the difference in the two engines? What makes the high output engine have more power? Can I change a chip or card in the computer to make the regular engine a High Output version? What would I need to do to convert the regular 4.0 engine to make it equivalent to the High Output engine?
XYKJohn is offline
post #2 of 7 Old 11-13-2004, 09:24 PM
EricsXJ
The Post man
EricsXJ's Avatar
Your 4.0L in the 2000 is a High Output also they just dropped the name.
From the specs sticky:
4.0L I6 EFI "Power Tech" - 177 hp @ 4750 rpm, 220 ft lb @ 4000 rpm - used 87-90
4.0L I6 MPI "Power Tech HO" (High Output) - 190 hp @ 4750 rpm, 220 ft lb @ 4,000 rpm - used in 91-95 and updated in 96-01 to 225 ft lb torque @ 3000 rpm (00-01 models use a distributorless ignition system)
I can't tell you why your older jeep seems like it has more power.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 7 Old 11-13-2004, 09:59 PM
madrabbitt
madrabbitt's Avatar
change the oil and airfilter in the new one.
see what that does.
and maybe if it needs a little more motivation,
you can get a high output sticker for it
http://www.4x4mods.com/Product/Whole...al40L/40L.html
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #4 of 7 Old 11-13-2004, 11:11 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
The difference could be gears. There could be minor differences in tire size and weight (97+ metal hatches 84-96 fiberglass).
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #5 of 7 Old 11-13-2004, 11:17 PM
Blake
Redefining body roll
Blake's Avatar
I bet the yeller' one would get it up to speed.
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
post #6 of 7 Old 11-14-2004, 12:19 AM
Lagooz00XJ
yeah i hear that those stickers add somehwere in the range of 10 - 12 hp to your engine
2000 XJ 4.0 aw4 np 242
Bastard 2.5" Lift
30" Kumho MT's
Belly Armor
RE H&T w/ front shaft
Lagooz00XJ is offline
post #7 of 7 Old 11-14-2004, 02:42 PM
Trippe
Trippe's Avatar
1997 XJ Cherokee
Location: Tampa: When Hell is just not hot enough for you!
i've got a bumper sticker that says "save the whales for later" and has a picture of a knife and fork...i got about 5 hp out of that alone..
1997 Green XJ 2 door
*RIP*
GREEN JEEP CLUB MEMBER #130
Parrothead Jeeper Union Member #1
Trippe is offline
4.0 high output vs. 4.0 santosdv XJ Cherokee Technical Forum 13 09-09-2008 08:29 PM
high output? txjeep103 XJ Cherokee Technical Forum 14 11-22-2006 03:59 PM
High Output? rosader XJ Cherokee Technical Forum 2 10-04-2006 09:15 AM
High Output TB sw19 XJ Cherokee Technical Forum 4 11-18-2005 06:14 PM
High Output MoodyXJ XJ Cherokee Technical Forum 5 06-05-2003 03:34 PM
