Quantcast High/low beam kit and an introduction - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > High/low beam kit and an introduction
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 10-22-2003, 06:19 PM   #1
Soul
I was racing through the mountains the other nite and realized that I wish I had more lights. I had my fogs and my lows on but still thought i could use some extra visibility. My friend mentioned kits for GMC/Chevy where you can set it up to run highs and lows together..I looked but couldnt find a kit and I have no clue how easy this is to do. Have any of you done it?
Anyway, since I am new to the forums, hello all!
I currently drive an 87' wagoneer limited with the 4.0l..even has that sexy wood siding.
Soul is offline   Reply With Quote
Old 10-22-2003, 07:13 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
The GM trucks use a two piece headlight, so it would benefit from the override you can buy. The XJ is a single sealed unit so it wouldn't really help that much.
You should look into the IPFconversion that is available. Here a couple of write ups to help you out:
http://www.jeepin.com/features/morelight/index.asp
http://www.jeepin.com/features/ipf/index.asp
Welcome aboard!
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 10-22-2003, 10:29 PM   #3
monkey boy
If your waggy has the two headlights, one above the other, thier may be a way to do this, I have not seen or heard of it, but,with a little research, I am sure it can be done! Good luck
monkey boy is offline   Reply With Quote
Old 10-23-2003, 12:54 AM   #4
EricsXJ
The Post man
EricsXJ's Avatar
Another option would be to just get a set of auxiliary driving lights. I am very impressed with the amount of light my IPF 868's throws out. I wired them just as the instructions recommend which means your Hi-beam must be turned on first, then you can switch the IPFs on or off and they will be on with your stock Hi-beams.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 10-23-2003, 03:51 AM   #5
Soul
Monkey, I have the two sets of headlights..thats why i was thinking it would be so easy to do...just dont exactly know how. I will havta research it abit..
Eric, I thought of that a little bit, but if i can get around adding more lights (for the moment) and maybe just doing a lil splicing. I may end up adding more lights, or following some of the things balloo linked.
I was just curious if anyone has done it..seems like it wouldnt be too painful.
We will see what i figure out and i will keep you posted. :-)
Old 10-23-2003, 08:54 AM   #6
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
I've thought of this too, running highs and lows together. I've held the switch right in the middle and both are on and lights up alot. The only thing that worries me is power. Is it to much for one bulb. I think it may put to much of a load plus extra heat could cause it to burst/blow.
As for doing it, if you want, I was thinking of using and aux switch with a seprate wire that turns on the highs. This way you could use the switch on the tree for normal use, and the aux switch for when you want both.
Matt
PS, hey Eric, I never understood why the driving light turn off when you hit the highs. The light I have, IPF900 are way to bright to have on road anyway, so you'd think it would be opposite, off with the lows??? I dunno.
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 10-23-2003, 11:00 AM   #7
EricsXJ
The Post man
EricsXJ's Avatar
No thats how mine work - they can't be turned on with with the lows. Do you have yours wired differently?
Eric
Old 10-23-2003, 11:13 AM   #8
Dirt Surfer
I never understood why the driving light turn off when you hit the highs. The light I have, IPF900 are way to bright to have on road anyway, so you'd think it would be opposite, off with the lows??? I dunno.[/QUOTE]
I know my name isn't Eric, but technically they are not driving lights, they are fog light. Fogs are mounted low so you don't get as much glare, and obviously, you don't use your brights in the fog, so you don't need your fogs with your brights. Just my $.02.
Dirt Surfer is offline   Reply With Quote
Old 10-23-2003, 12:44 PM   #9
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Well the IPF 900 are driving lights, they are both spot and wide beam in one lens. Fog lights are usually amber, and are spot lights.
Yeah Eric, you must have reversed the instal then, Cause the instrustions said to tap into the low beam wire so when the highs are on, the IPFs are off. I like your set up better. I may switch the wires. The only things that sucks is my high beams look at the tree tops, even though my lows are level. Crapy lens I guess.
Matt
Matt
MY XJ PICS
Old 10-23-2003, 01:13 PM   #10
99XJSPORT
I replaced my headlights with the Hella H4 conversion lenses and PIAA bulbs. It wasn't cheap but they are much brighter and the aiming of the beam is much cleaner and crisper. These along with the PIAA fog/driving lights(I replaced the Jeep fogs) give me incredible peripheral and straight ahead visibility.
99XJSPORT is offline   Reply With Quote
Old 10-24-2003, 04:26 AM   #11
EricsXJ
The Post man
EricsXJ's Avatar
Yeah Eric, you must have reversed the instal then, Cause the instrustions said to tap into the low beam wire so when the highs are on, the IPFs are off...
I am 100% sure I installed mine correctly per the instructions which I still have. Maybe the 868's vs 900's are wired differently, but the way you describe doesn't make sense at all. The reason mine only come on with the Hi-beams and not the lows are so you don't blind people in front of you. The theory is if you don't need your Hi-beams on, then you wouldn't need the aux. driving lights on either. It just makes no sense for them to come on with the lows but not with the hi's...
Eric
Old 10-24-2003, 06:19 AM   #12
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
99XJSPORT, how much do those Hellas cost. I got some cheap ones made by Eurolite or something. The look great and low beams are awesome but highs are just to high. Maybe I'll switch to the Hellas if they aren't to bad.
Eric, I looked at my instruction sheet today and it does say the go off with the high beams. So mine are hooked up right too. I'm gonna change them tonight.
Matt
Matt
MY XJ PICS
Old 10-24-2003, 09:10 AM   #13
b(k)ill94xj
matt before you do that, call the dmv and ask them, im pretty sure that they have to be wired so that they will come come on with the highbeams on. if you have them on a switch were you can turn them on whenever u want you wont pass inspection...but idont if its true for PA since u are going over there now.
Rocks bite hard, but trees just piss me off...
97 Wrangler sport - 2 inch RE BB - Teraflex adjustable trac bar - 3.73's d30 and d35 - 31x10.5 yokhama geolander's - 15X8 American Racing Outlaw 2 wheels 3.75 backspacing - JKS LCA skids - hella vision headlights - Alpine amp and 6.5 type S speakers
94 Cherokee Sport - 3.5 Rubicon Express Kit - RE adjustable trac bar- 31X10.5 Kumho Venture MT's - 15X8 Crager Soft 8 Class III Hidden Hitch - Hand Throttle - High flow cat w/ Delta Flow 40 muffler Transfer Case Skid Plate Removable Doors --SOLD :( :( i miss it so much
b(k)ill94xj is offline   Reply With Quote
Old 10-24-2003, 10:07 AM   #14
99XJSPORT
Matt - I think they were like $30 each, but it could have been.
here's a link for 70/pair
http://www.jeepline.com/store/itemdetail.asp?ID=4774702
As far as the high beams and "extra" lights they are not supposed to be on together, hence why the factory wiring from Jeep automatically turns the fogs off when the highbeams go on.
Chris
Old 10-24-2003, 11:48 AM   #15
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
As far as passing inspestion, I really don't care about that. There is so much stuff I have to play with to pass that taking them off really doesn't matter. Let me think, I need to put stock headlights in, Amber turn signals, take off fogs, fix reverse lights, balljoints possible use stock bumper??? possible lower a few inches??? Oh yeah, I Jersey you can't have a check engine light anymore, good thing I'm in PA now. I think thats it, but i'll probably fail for some other BS after doing all that stuff. I'm gonna be pissed if they make me lower it a few. I think I don't have to worry about emissions, but thats not a problem, yet. i think thats about it. I need to find a garage that'll pass anything.
So PA people, who does your inspection????
Matt
MY XJ PICS
Glock Forum
