#1 | |
High Idle when weather is nice.
I forgot about this problem because it went away when winter came but now that it's getting warmer it's starting to come back. It's directly related to the outside temperature.
Normally whenever I start my jeep it idles high for a few seconds then settles down to a comfortable level. However when it's a warm day out it is inevitable that it will remain at a high RPM after starting it and never "settle down" as I would normally expect. I can tell even before I start it whether or not it will do it by whether it's a hot or cool day... very predictable. I have a standard tranny and it idles higher than I would normally want it when I take off from a stop. Then when I pull into a parking space and am going slow I push in the clutch and brake to stop and the motor rev's up since it's no longer under a load. Thanks.
1990 Cherokee, 210k Miles, 5-Speed, 4.0 1988 Cherokee, 243k Miles, 5-Speed, 4.0 |
#2 |
It's just your Jeep's way of saying it likes the nice weather.
![]() Just kidding......but I am having the exact opposite problem. My idles high when its cold.
94' XJ |
#3 |
i would say that it idles high when its cold b/c its just tryin to warm up...like a choke does. i have no idea why it would idle high when its nice outside though
#4 |
Is there a check engine Light on? Do you ever notice black smoke coming from the tail pipe? Is it on the 90 or the 88 ?
could be an idle sensor?
[CENTER][FONT="Century Gothic"][COLOR="DarkRed"][SIZE="4"]1985 Cherokee Laredo [/SIZE][/COLOR]- New 3.2L Crate Engine - Bored .60 Over - Comp RV Cam - New 390CFM Weber 2-barrel - Accel Wires - MOOG Distributor - Rebuilt TC904 3-speed auto NP229 - Custom Rear U joints - Custom Flat Black Paint - Herculiner over rebuilt floor pan -Jeep For Life[/FONT][/CENTER] |
#5 | |
#6 |
its one of those jeep things mine does its aswell.......you start it revs to like 3000RPM sticks.....you kill it......start it again does the same thing.......then third times a charm ...... ive gotten used to it however i have noticed that it wont do it for a while after i give my TB a slight cleaning and oiling......so give that a try spray it down with carb cleaner and oil the linkage and such
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit My Jeep's Page |
#7 |
check your TPS. common problem on the cherokees.
"Few men are killed by the bayonet, many are scared by it. Bayonets should be fixed when the fire fight starts" - General George Patton Jr, "War as I knew it" 1947 new vehicles:1996 Ford F150 5.0l 4X4 with a plow. |
#8 |
even after i replaced mine it still did it
#9 |
Damn, my 90 does the same thing. It seems when the engine bay warms up (so warmer intake temps and such) mine idles higher. When it is cold, it nearly stalls!
There must be some sort of intake air temp sensor that is wigging out on us. Do let us know what you find, I will do the same.
1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
#10 |
mine does the same, except that it does it when the engine is hot and I turned it off and it sits for at least 5 minutes and I restart it and the idle is at 3000rpm. I have replaced the TPS and cleaned the idle controller and cleaned the throttle body. I don't know what else it can be, but it will ruin my tranny soon cause I have to put it in gear at that high rpm. anyone have a solution????????
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
