High idle problems - JeepForum.com
post #1 of 12 Old 07-24-2011, 02:56 PM Thread Starter
hotrod500
1990 XJ Cherokee
High idle problems
My '90 cherokee is having some idling troubles. Its not an all the time problem but about 50% of the time it wants to idle high for no apparent reason and only stops if i cut it off and back on and that only fixes it sometimes. And even then it most likely will start to idle high again later and ill realize when i try to stop it makes it hard because its still trying to accelerate. Can anybody tell me what it might be???
hotrod500 is offline
post #2 of 12 Old 07-28-2011, 06:44 PM Thread Starter
hotrod500
1990 XJ Cherokee
ttt
post #3 of 12 Old 11-27-2013, 11:01 PM Thread Starter
hotrod500
1990 XJ Cherokee
ttt
post #4 of 12 Old 11-28-2013, 01:58 AM
copmedic309
1995 XJ Cherokee
Clean out your throttle body and clean your idle control sensor, it's in the back of the throttle body. Throttle body cleaner recommended, not break cleaner. Good luck
Ry
Better tried by 12, than carried by 6.
Ry.
Rather be tried by 12, than carried by 6.
copmedic309 is offline
post #5 of 12 Old 11-28-2013, 04:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Your TPS is probably dying on you.
I would first do a ground refreshing, post 1.
Sensor ground test, post 5.
TPS test, post 8.
All in the link below.
A throttle body and IAC cleaning is NEVER a bad idea as has been suggested already.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #6 of 12 Old 11-28-2013, 07:21 AM
cumminsjeep24
1997 XJ Cherokee
replace the cps and also check for vacuum/intake leaks. Its more unlikely since you are only getting it to do it half the time, but anything is possible.
97XJ 97TJ 11WK2
KCCO
cumminsjeep24 is offline
post #7 of 12 Old 11-28-2013, 07:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
CPS WILL NOT cause high idle issues. That would be an unnecessary expense and time waster.
post #8 of 12 Old 11-29-2013, 07:51 PM
Max78
1992 XJ Cherokee
As stated, check your TPS when its idling high, and clean your IAC (Idle Air Control valve)and be sure to clean the throttle body as well.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #9 of 12 Old 12-02-2013, 09:24 AM Thread Starter
hotrod500
1990 XJ Cherokee
thanks guys!
post #10 of 12 Old 12-03-2013, 04:07 AM
oakmckinley
Too bad to took us two years to respond to this thread.
The PO probably sold the jeep already....better late than never I guess.. Hehe
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #11 of 12 Old 12-03-2013, 05:09 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
On 11-27-2013, he posted ttt.
post #12 of 12 Old 12-03-2013, 08:22 AM
Max78
1992 XJ Cherokee
Ya, but its still pretty sad it took 2 years to get a response.
Max78 is offline
high idle , idle , idling , throttle
High idle speed problems? Renix 4.0L XJ_hoghunter XJ Cherokee Technical Forum 0 01-29-2011 02:52 PM
Problems wiring a high idle switch in (searched) Jameslol XJ Cherokee Technical Forum 0 04-02-2010 02:02 PM
Death Wobble, Idle Problems and Winshield wiper won't turn on until set on high bermudaJEEP XJ Cherokee Technical Forum 4 09-24-2008 10:19 AM
newbe XJ owner w/ high idle problems notspock XJ Cherokee Technical Forum 8 01-17-2006 10:40 AM
High idle and rev problems briand XJ Cherokee Technical Forum 2 11-01-2003 02:06 PM
