High idle, long hot crank - JeepForum.com
post #1 of 2 Old 09-06-2013, 07:26 PM Thread Starter
brak876
Still ironing out the bugs in my 96 cherokee 4.0. It starts up fine when the engine is cold but when it warms up it idles high and when shut off and restarted while the engine is still warm it has about a 3-5 second crank. It also stumbles when you push the gas quickly. I recently installed a new distributor/cam sensor/cap/rotor(came as a complete assy) and spark plugs about 250 miles ago. It was doing this b4 the install and went away after but has returned.
brak876 is offline
post #2 of 2 Old 09-07-2013, 09:01 AM
psychoteen101
When its hot, test the CPS to see if its out of range. They tend to get heat soaked and cause problems when the jeep is hot.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
